16-01-2006, 06:26 PM | #1 | ||
wondering if these are good for stereos and car starting?
Will 40 amps an hour 12 volt deep cycle battery be enough?
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
16-01-2006, 07:43 PM | #2 | ||
Former E-Series Member
The specification to look out for is Cold Cranking Amps. Optima batteries are popular, with the red top model around 800 CCA. Apparently the yellow top model is more suited to cars with big stereos.
http://www.optimabatteries.com/ |
17-01-2006, 08:15 AM | #3 | ||
rofl copter
all odessey batteries are deep cycle, i have a battery the size of 3 in my back yard, 200 amphours, sat there for 3 weeks on the concrete, then used it to jump my old mans car wen the battery died! started first go!
GQ patrol.
.... thats all |
17-01-2006, 08:18 AM | #4 | ||
The one and only
I have a Optima Yellow top.
Ran it flat many times and it still holds charge. I use it for thar reason and for the audio.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
17-01-2006, 08:20 AM | #5 | ||
Which yellow top do you have Wayne?
I need to get one of these as well soon for the torry.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
17-01-2006, 09:18 AM | #6 | ||
Grr cant edit.
That odyssey one is tiny at only 3 inches thick!! It looks like the yellow top D34 would be the best for running a stereo with the car off. Does anyone know a good place to buy these that would be cheaper than autobarn?
17-01-2006, 11:14 AM | #7 | ||
rofl copter
theres a few different types of odessey batteries, the 3" thick ones arnt good but are pretty good for thier size, i wouldnt run em on a stereo setup, just run one with a big CCA eg 600-800 and run a capacitor aswell, have a solenoid in between the 2 batteries and run the trigger off the alternator so wen the car is running the 2 batteries will connect together, that way u dont flatten ur main battery if ur just sitting in a car park listening to music.
GQ patrol.
.... thats all |
17-01-2006, 03:55 PM | #8 | ||
Shoot.
Dan, try these guys: http://www.fastfoursforumscarclub.co...s/specials.asp
They were having a sale on Optimas a little while back, but not sure if they are still on special.
20V Turbo |
17-01-2006, 05:04 PM | #9 | ||
Damn that Odyssey looks cool! I imagine it would have a serious weight advantage over Optima. Rollin, what did you pay for yours?
17-01-2006, 09:26 PM | #10 | ||
Ute Forum Moderator
Any of these type of batteries will have plenty of cranking amps to start the car (remember the standard battery is 460CCA or so), if you are looking at using it to run a stereo without the engine running, you need a lot of reserve capacity. And that is something that the "small" batteries don't have a lot of.
18-01-2006, 11:00 AM | #11 | ||
so is 40ampa per hour ok??
18-01-2006, 10:00 PM | #12 | ||
18-01-2006, 10:07 PM | #13 | ||
Gunna girlie-man
i dont know if this helps at all, but the standard battery for an eb 2 is:
cold cranking amperes: 400 reserve capacity : 95mins Ampere Hour: 53 and the alternator is as follows: 70 amp (6cyl) 85amp(5litre v8) or if you want a battery with more cold cranking amps, use a battery out of a new F250, they are 600 cold cranking amps!!!
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
18-01-2006, 10:20 PM | #14 | ||
Optima have ones available up to 900 Cranking amps
18-01-2006, 10:22 PM | #15 | ||
yer mate cheers that help it seams the battery i was looking at wont be good enough as u said the standard on is 53 amps per hour
18-01-2006, 10:26 PM | #16 | ||
Gunna girlie-man
what do the cold cranking amps do????
why is it the more the better
19-01-2006, 01:08 AM | #17 | ||
Cold Cranking Amps is a rating used in the battery world to define a battery's ability to start an engine in cold temperatures. The rating is the number of amps a new, fully charged battery can deliver at 0° Farenheit for 30 seconds, while maintaining a voltage of at least 7.2 volts, for a 12 volt battery. The higher the CCA rating, the greater the starting power of the battery. Mine is rated at 550CCA which is not the best, but better than most i've seen in an i6
20-01-2006, 11:48 AM | #18 | ||
I have been researching the Odyssey 680 MJT and it seems a decent online price is A$225 from "www.modyourcar.com.au", or US$70 from a respected specialist Ebay US seller. It seems this is an automotive version of a motorcycle battery - its only weakness is in the amp hours department.
I'm awaiting clarification of the postage costs from the US. I would pay extra to buy from a local supplier, but not double the price or more... :( |
20-01-2006, 11:27 PM | #19 | |||
Ute Forum Moderator
21-01-2006, 12:19 PM | #20 | ||
Rollin,
I can't get over that it only weighs half a kilo. If someone finds a good deal on them let me know. - John |
21-01-2006, 12:23 PM | #21 | ||
E-Series Firemaker
I'm running 1 Exide Orbital marine dry cell and 2 Exide Orbital deep cycles dry cells... They're all around 770CCA but the marine battery is better for the stereo because it can hand out larger dosages of power for a reasonable amount of time, the deep cycles are better for smaller dosages of power but they do it for much longer... They're a tough battery, you'll do well with any of the major brands, optima, exide orbital, odyssey, etc
Alex |
