Old 21-01-2006, 10:41 PM   #1
eav8
eav8's Avatar
Default bent crank???
how do I test for a bent crank without removing from the engine
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo
Fully road legal and cruising in QLD!!
Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus
eav8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2006, 10:45 PM   #2
mcflux
mcflux's Avatar
I don't mean to sound like a smartarse, but wouldn't starting it give you a fair idea?
Old 21-01-2006, 10:49 PM   #3
eav8
eav8's Avatar
well that,s just it...I have started it and is sounding wrong (a catch slap type of noise) but it sounds in the top end....I have removed the driver's side head (v8), checked lifters, removed gearbox,bellhousing, starter motor....when turned by hand nothing is catching...No bores have scoring (thought broken ring)
Old 21-01-2006, 10:50 PM   #4
LUXO_8
windsor user
its not something craxy like something on the engine tapping against the body work?
Old 21-01-2006, 10:52 PM   #5
eav8
eav8's Avatar
thought of that but a bit tooo loud I feel...I have a mobile phone recording of it running but don,t know how to upload it for viewing (.3gp format)
Old 21-01-2006, 10:59 PM   #6
eav8
eav8's Avatar
anyone? I'm taking the sump off tomorrow and would like to not have to completely dismantle the engine unless absolutely neccessary
Old 22-01-2006, 12:53 AM   #7
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
could it be a stuffed gudgeon pin? i think thats whats wrong with my xc's 351. a steady knock, like its on one cylinder. maybe ask in the clevo forum.
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 01:10 AM   #8
mik
mik's Avatar
if the engine done heaps of ks might be piston slap
Old 22-01-2006, 01:19 AM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
Depending on how bad, you cant..
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 22-01-2006, 10:45 AM   #10
eav8
eav8's Avatar
Engine recently rebuilt by myself..First full rebuilt as 302c then got crank etc and converted to 351c...This is the first time I have undertaken a full engine rebuid so I was expecting some teething problems.
I just would have thought that with a bent crank that when turning it by hand it would have gotten noticably harder to turn in certain positions?
Old 22-01-2006, 04:05 PM   #11
svo347
AFF's 1st DM.......
svo347's Avatar
check your main bearings
13.21 @107.7mph
Old 22-01-2006, 05:02 PM   #12
eav8
eav8's Avatar
thanks for suggestions it turned out to be a dodgy valve guide install. All but 1 valve stem (exhaust) had been fully removed. The at fault one had merely been fitted with and insert of some kind. This insert then proceeded to seize up on the valve stem causing it to catch a little then release violently..thus a slap sound....Needless to say the old valve guide was nothingbut a jagged mess. It just disgusts me how they could do all the others completely then shortcut so badly....Must have been getting near to knock off time for the day. :(
