Old 23-01-2006, 02:25 PM   #1
jlkass1
Default EL 4.0L head gasket
Hi There,
I'm about to do a EL headgasket (1st time on an EL) and was wondering if there are any tricks or tips to be weary of?
Thanks,
James.
jlkass1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2006, 02:39 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
Yeah use new head bolts, use AU head gasket, and torque it down as per AU specs.
dump 100% of coolant.
make sure both the head and block are 100% clean and straight before bolting back together.
Old 24-01-2006, 09:03 AM   #3
jlkass1
Thanks for the info - will an AU head gasket kit be ok - ie. manifold gaskets the same..etc..
Thanks again,
James.
Old 24-01-2006, 09:08 AM   #4
EA2BA
PM me if you want
EA2BA's Avatar
yes manifold gaskets etc are the same you can bolt inlet and exhaust from ea to au.
Old 24-01-2006, 09:10 AM   #5
ilsautomotive
Former E-Series Member
I'd have the head shaved as well, it's the only way it will be truly straight.
Old 25-01-2006, 03:27 PM   #6
pagedm
Be REAL carefull when removing the head if you don't intend on replacing the timing chain guide. If you twist or move the head around when removing or replacing it the guide will snap pretty easy. If you do you will have to drop the sump and remove the timing cover to replace it.
pagedm is offline   Reply With Quote Multi-Quote with this Post
