Old 27-01-2006, 05:26 PM   #1
laybourne
Default ECONOMY automatic transmission
What exactly does Economy mode do on an AU?
Old 27-01-2006, 05:34 PM   #2
rayner22
rayner22's Avatar
It changes the revs at which the box changes gears to make it supposeably run more economical. Without it on the box just changes at optimal revs for power and acceleration etc. Economy is good for round town but i find it better in normal mode on highways etc
rayner22 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 05:37 PM   #3
Baboon_AU
Baboon_AU's Avatar
search it and there are plently of threads about it.
basically its a rpm limiter, it like to change gears at around 2000-2500rpm, where as if u didn't have it on, it would rev right up to like 3000 or even higher depending on how you drive. less rpm, the less fuel u use
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
