Old 10-02-2006, 10:16 AM   #1
Laminge
Cuban... nothing like it
Default Email Help Request
Hi my name is Mark and i have a massive prob i am trying to fix my mums eb falcon
Here is what happened
I drove the car to qld for new years it went up and back no probs the next day she tried to start it and all it would do was wind over
We were told it was the modulator on the dizzy so we got it tested and it was stuffed so we replaced it
The dizzy was take out to do this
I have put the dizzy back in best i no as top dead center on compression stroke but it is only winding still no firing at all
I used the first timing mark on the left o it also is on dual fuel
could you please help me as i am costing my mum money every day i cant get this thing going as she cant get to work any more
thank mark
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 11:05 AM   #2
Simmo
White Lightning
Simmo's Avatar
ha i knew it. laminge is really a young kid with an internet ego :P.
i'd be checking for spark against the block and that fuel is definitely getting pumped through.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 11:18 AM   #3
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
See if you can get 12V going to either side of the coil because even if the dissy is in the wrong position you still should get a misfire. Is it possible that the new modulator is also buggered?
hako is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 11:27 AM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I guess the timing is way out on the distributor then? There isn't a huge amount of detail. First, I'd double check everything is plugged in, and theres spark coming from a lead.
If you look for Top Dead Centre (TDC) on the harmonic balancer, which is behind the crank pulley, you should see the timing marks for TDC. Crank the motor so the marks line up (there is a pointer attached to the block which lines up with the balancer marks) with TDC, then set the distributor so it's pointing to where #1 lead is.
Thats as about as close as you will get it, then you'll need to set the timing properly with a timing light. I'm not 100% sure, but I think base timing for an EB 6 is 10deg, someone else should know.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 12:12 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Whats stopping it from pointing to #1 on the exhaust stroke or induction stroke, you'd be X degrees out...
Personally id remove the rocker cover to see what the valves were doing in relation to the firing order
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 10-02-2006, 01:44 PM   #6
Walkinshaw
Two > One
Walkinshaw's Avatar
Start back at the coil.
Remove the HT lead from the coil, put a longer (dizzy==>plug) lead on the coil and try and see if the coil is sparking at all.
NO==> remove coil and test it
YES==> Re-connect coil to dizzy
Spark from a spark plug lead on crank
NO==> check TFI(already done)
YES==> check timing (as said above)
