Old 13-02-2006, 03:53 PM   #1
jt119
Default going nuttes
got an ea 91 the car goes 4 about 10 to 15 mins then cuts out and wont start 4 a day or to theres no spark and can push fuel line together ive put other dizzy in and still does it put other coil on it still does it when it does go it seems abit down on power at take of what more would make it shut down like this
jt119 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 04:49 PM   #2
GenesiS
*Smart *** comment here*
GenesiS's Avatar
Not being rude, just tell me if this translation is correct, cause I'm slightly confused...
You have a 1991 EA Falcon. It runs for about 10 to 15 minutes and then shuts off. Once it has shut off it will not start for a period of about a day or two.
There is no spark from the spark plugs and you are able to push the fuel line together. You have tried another distributer and the problem remains, you've also tried another coil and the problem still remains.
You have also noticed that when it is going it does not seem to have much power.
Is this correct?
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 05:18 PM   #3
AshMan
Girrrrr!!!
AshMan's Avatar
Maybe try tightening all of the battery terminals and check all the connections on your ECU (which is located behind the passengers side front kickpanel) and maybe when you check your battery terminals take them off and rough the lead part and the bolt on part of the terminal so that they are shiny, bolt it back together, and cover in liquid electrical tape.
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 07:22 PM   #4
jt119
yip u got it right
