25-02-2006, 09:09 PM | #1 | ||
turbo kid
I had a crack at the search function but didnt come up with anything. What i wanted to know is, i removed the plastic cover for the cassete player and the player itself is held in by two golden coloured screws with a weird screw pattern on the top. I guess everyones had the same problem upgrading to a cd player, so can anyone tell me where i can get the tool to undo the bastards?
25-02-2006, 10:25 PM | #2 | ||
Low and Loud
Those screws are called TORX screws. T25 torx bit IIRC. These are available in a set from dicksmith, autobarn, bunnings, Mitre 10, etc.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
25-02-2006, 10:27 PM | #3 | ||
Gunna girlie-man
is that the allen key sort of screw with the raised dot in the middle?? if it is, just get a good pair of pliers and squeese the screw and turn it to loosen it
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
25-02-2006, 10:30 PM | #4 | |||
Low and Loud
Those screws also serve a purpose as it makes the little bugger who is trying to flog your stereo work a little harder to get it.
25-02-2006, 10:55 PM | #5 | ||
turbo kid
yeah i was planning on keeping the screws in place just adopt them to my cd player, i figgured not many people would have a set of torx keys:voldar02:
25-02-2006, 10:57 PM | #6 | |||
Low and Loud
25-02-2006, 10:59 PM | #7 | ||
Gunna girlie-man
when you install the cd player or whatever, the screws that hold your door trim to the inside of the door, will fit the thread of the torx screw
26-02-2006, 01:01 AM | #8 | ||
You will need to attach the Torx tool to a cordless drill, because as Mich mentioned they are in very tight. I tried the plyers trick and that didn't work either. I picked up a set of 24 Torx for $9.99 at Dick Smith.
