Old 22-03-2006, 06:01 PM   #1
smiley
Default ea needs a belting
g'day all.
I'm currently replacing the head gaskets and other gaskets on my ea cfi. now i've got the rocker cover, radiator and manifolds disconnected. I'm trying to set the timing mark to line up with TDC. In my instructions, it says to rotate the engine clockwise by hand by grabbing the belts but they won't budge no matter how hard i try. Does anyone know how to rotate the engine by hand? (and it is in neutral if that makes a difference).
smiley is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 06:06 PM   #2
brenx
brenx's Avatar
you put a rachet and socket on the balancer bolt and turn it. By hand is just plain silly.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 07:15 PM   #3
smiley
damn, my biggest socket is just slightly too small.
Old 22-03-2006, 07:21 PM   #4
Damo
it's a 22 mm bolt so you know, Turn it clockwise and make sure it's on TDC on compression stroke. Pull out sparkie No1 and stick a finger in there till you feel air and that is compression stroke.
Old 23-03-2006, 01:22 AM   #5
smiley
lol, my biggest is a 21, better hunt down sum1 else. cheers
Old 23-03-2006, 08:16 AM   #6
EA2BA
PM me if you want
EA2BA's Avatar
a 22mm socket from repco is less then $10 i recall when i had to get one.
Old 23-03-2006, 12:24 PM   #7
smiley
k, i got the right sized socket but when i try to turn the crankshaft pulley, it just won't budge!
Old 23-03-2006, 12:34 PM   #8
brenx
brenx's Avatar
You sure you've got the cam timing correct? If you haven't it'll have pistons hitting valves. If thats not happening? You need more leverage. Like a big breaker bar for example.
Old 23-03-2006, 12:35 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
Have you got the spark plugs out, makes it far easier to turn it over if like brenx said check there is nothing hitting.
Old 23-03-2006, 12:43 PM   #10
smiley
sweet, i got a bit of a rocking motion on the wrench and that got it to turn and now i've got it all lined up. Thanks for the help. :
