22-03-2006, 07:18 PM | #1 | ||
Hi again to all,
Thanks for all the advice I have been recieving so far it has been very helpfull, especially the advice about my power steering, it turned to be the powersteering switch that was leaking. I have another question....I noticed on the weekend as I had the car up on ramps and was moving the steering that there is 2 bolts holding the power steering rack onto the chassis or K frame or what ever it is that the whole rack was moving as if the rubber bushes around the bolts were worn.......??? Also I have taken my battery out a few times and each time had to put in the security number again to get the radio working, but the last time I did it it did not work....my number is 4522 but each time i do it the first number comes up very small and the other numbers are bigger..........??? Thanks again |
22-03-2006, 10:01 PM | #2 | ||
Try tightening those bolts holding the rack on - on our EB they were slightly loose despite never boing previously touched. On the battery make sure the terminal connectors are clean and tight.
22-03-2006, 10:06 PM | #3 | ||
the numbers are always different sizes.. it doesnt make a difference. as long as you have the right code and havent entered the wrong one in a few times then it should work.
