26-03-2006, 08:32 PM | #1 | ||
Hey everyone,
I was cruzin down the freeway @ 100km/h just under 2000rpm and suddenly there was a clunk which jolted the car and then kicked the auto transy back into 3rd @ 3000rpm and it would not go back to 4th. So i pulled over and checked over the usual, found nothing out of the ordinary and took off again then everything was fine after that. I also had the neutral switch on the transy replaced for new 1 month ago because it was changing from 4th to 3rd always on the freeway and that problem has gone since then. I'm thinking maybe the culprit is a solinoid in the transy but my question is can a solinoid from the transy activate limp home mode? Cheers. |
26-03-2006, 08:45 PM | #2 | ||
Turbo Falcon Fiend
MMmmmm what about the plugs on the side of the tranny. I have had to hit mine with contact cleaner a few times to avoid Limp Home Mode.
Just a few. |
26-03-2006, 11:48 PM | #3 | ||
Location: I live in my own little world, but it's alright, the people know me here
Das car does that sometimes I think, i can never really tell cause it's only ever done it in 80 zones, but it doesn't shift down a gear it just doesn't go up into fourth in the first place
Man who walks through plane door sideways is going to Bangkok. |
27-03-2006, 12:03 AM | #4 | ||
they call me Tibbo
From reading your original post, you mention you took off fine after that? If that is the case I am assuming you have 1,2,3 but no 4th? Thats not limp home mode that is no 4th gear.. A solenoid failing won't make a noise, but are you saying it is fine now (ie have 4th gear back?)
27-03-2006, 12:08 AM | #5 | ||
[EBGLT]
This is exactly what mine was doing i just got a service and i aint had a problem since!!! Check your fliuds too mate!!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
27-03-2006, 12:10 AM | #6 | ||
What Wheelspin?
limp home mode will leave u in 3rd gear till you turn the car off. wont downsift or anything. sometimes this is due to low voltage to the tranny. chech to see that you battery has no "gunk" around the terminals
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
27-03-2006, 12:11 AM | #7 | |||
27-03-2006, 12:19 AM | #8 | ||
[EBGLT]
Thats exactly what happened to me!!!!!!!!!!!!
27-03-2006, 01:03 AM | #9 | ||
V8 Ute V8 Boat
Dont mean to tax this post but my car some times cuts out first gear till i turn it off and start it again the it will work again what could this be
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
27-03-2006, 01:12 AM | #10 | ||
Oops, I slipped....
If you do a diagnostic test to the car it will tell you why it went into limp home mode.
http://www.fordmods.com/forums/documents.php?doc=52
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
