I have a 91 XR8 and every now and again my auto heats up that much the shifter is pretty much unberable to touch:(???????????
Its not peer presure..........Its just your turn! XE project underway ![]() |
V8 Ute V8 Boat
could be somthing stuck in the trans cooler
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
#3 | |||
Turbo Falcon Fiend
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
Girrrrr!!!
I've found that the shifter and trans tunnel are very good guages of how hot the gearbox is...
maybe one of the trans cooler pipes are kinked or something??? other than that it buggers me.
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
Oops, I slipped....
Have you got an aftermarket trans cooler fitted? How close does the exhaust come to the shifter linkage? I'd have a guess and say the exhaust is more the problem than the trans heating the shifter.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
It's the hole gear box that heats up, Iwas just explaining that it gets that hot the shifter heats up, If I pull the pan off the auto, and the trans cooler has gone would there be bits of brass or copper what ever the coolers made of in the pan????????
I"m not sure if the trans cooler has been changed
#8 | |||
Girrrrr!!!
thats what the bloke from the auto place in Geelong told me
Custom user title
Yes. The bits of copper in the pan will be from the auto cooler.
