02-04-2006, 10:55 PM | #1 | ||
Location: Under the bonnet, trying to keep as clean as above!
hi all well i'm about to put all the motor back together and just wanted to check with you guys first on what to do. i'm not sure if this is a stupid question or not and i have asked many ppl and they don't know, but with the head gasket it has one whole punched through the each water jacket? do you just leave it like this or cut out the whole water jackets? and i have heard the au head gasket gives a litlle more compression compared to the eb head gasket. is this true? thanks
03-04-2006, 02:21 AM | #2 | ||
use the au gasket m8, 100% improvement.. and you dont cut the galleries out, just leave the hole in the middle
03-04-2006, 11:02 AM | #3 | ||
Oops, I slipped....
Yep, AU gasket is slightly thinner, but more importantly, virtually fixes the problem E-Series I6's had with head gaskets. Best to leave the jackets blocked on the head gasket, I'm not too sure on why they're blocked either, but there must be a reason behind it....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
03-04-2006, 11:15 AM | #4 | ||
FPV GT Owner!!!
They are blocked in order to dispurse water flow evenly throughout the head.
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
03-04-2006, 05:58 PM | #5 | ||
righto. so the au head gasket will fit straight on, don't have to do anything to it? and what series au head gasket or are they all the same?
03-04-2006, 06:40 PM | #6 | |||
Girrrrr!!!
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
03-04-2006, 06:53 PM | #7 | ||
all same
03-04-2006, 06:54 PM | #8 | ||
make sure you get genuine though, cos the aftermarket ones arent mls (multi layer steel)
