Gunna girlie-man
hey guys just reporting about my fairlane instrument cluster conversion. no probs at all, only confusing part is wiring up the door ajar sensors or how ever they work, any tips on doing this part, thanks.
cheers scott
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
GTHO FAN, I'd connect the door ajar wires to the interior light switch thingy's on the door jams.
good work mate... I once put a xf digital cluster into my old s pack. Looked pretty sweet.
As far as the door sensor goes, I'm just having a guess here but one would asume there would be 4 wires (one for each door) that would go to ground when opened. This would then trigger the light on the dash. It could also be controlled through the BEM, so you might even need to get that if you want it to work. That way you would also get the extra's - fading dome lights, adjustable dim/brightness of the lights for the cluster etc... I am only guessing though - I'm sure someone would know, or even have a wiring diagram you can look at. Cheers Matt |
#4 | |||
Gunna girlie-man
#5 | |||
windsor user
the door adjar bit is a nightmare of wiring. each door has a microsensor in the latch ( go have a look in a fairlane)with wiring going to the cluster........ its crap |
Gunna girlie-man
ill head down to pick a part again tomorrow, and check it out wayne, and also ill have to get the oil pressure switch, because like the guide on fordmods says, it will glow dimly without it, and yep it sure does
Low and Loud
Yeah i was stoaked with my Digital tacho when I first fitted it, but then the call of the Spack cluster was too strong and i went back to the dark side hehe
Dont want a NC2 Fairlane cluster with smartlock LED do you? im throwing it out
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Gunna girlie-man
nah, i had to make sure it was a pre smartlock dash, as i only have an ea s-pack
