10-05-2006, 10:15 PM | #1 | ||
Opinions Wanted
Not long ago I purchased a 95 Fairmont with 197k on the clock. Now I can hear lifters going, and am considering the following: 1) for a little more grunt, replace Head with an Xr head from an EF or EL maybe AU. Where would the best place to find one of these? and will it be worth it with the orig ECU? 2) Buy my wrecked manual Xr6 from the auction, rip out what I want and flogg off the rest including what I pull off the fairmont as parts to cover the cost. I would be taking the wheels, motor / head, manual, diff, springs & shocks, and exhaust from the XR. The back half of the Xr is in good condition. 3) replace lifters as they go screwey Cheers Dan |
10-05-2006, 10:19 PM | #2 | ||
do number 2
10-05-2006, 10:20 PM | #3 | ||
Last warning
2....
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
10-05-2006, 10:39 PM | #4 | ||
im for 2 2 :P
10-05-2006, 10:39 PM | #5 | ||
^^ What they said^^
10-05-2006, 11:35 PM | #6 | ||
2 what else:P
10-05-2006, 11:39 PM | #7 | ||
2 for sure
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
11-05-2006, 12:24 AM | #8 | ||
BA XR6
Guess what i'm gonna say?
2 you guessed it :P
Phantom BA XR6 Falcon |
11-05-2006, 04:23 PM | #9 | ||
I'd throw the EL XR head on the EF. You'll never get your money back in parts. If the XR is wrecked, chances are the suspension is bent, the exhaust is ed too. Its a load of work pulling the motor out and you're essentially replacing it with the SAME THING as your motor with an XR head.
Unless the XR has <100,000kms, I'd be spending the money you have to buy the wreck on a new head & cam. Perhaps a manual conversion will present itself down the track...
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
11-05-2006, 04:29 PM | #10 | |||
Back to Le Frenchy
2. But only if you can get it for the right price.
11-05-2006, 05:11 PM | #11 | ||
4
errr I mean 2. |
