Old 10-05-2006, 10:46 PM   #1
frtmatt83
ANOTHER FORD DRIVER
Default rust
I got some surface rust showing i don't have enough money to get it resprayed. I am going to undercoat it being my first time i don't know want to do or what to use can anyone tell me what i need to do.
any help would be great
matt
frtmatt83 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2006, 11:17 PM   #2
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
well i'm guessing that is the wheel arch? um with my old man being a boilermaker he would cut it out and weld a new peice in there but i don't know. i'll ask him and see what he thinks. all i can thinkofat the moment is that or some rough *** sand paper? like i said i have no idea.
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2006, 11:26 PM   #3
Holbrookau
OPT 20
Holbrookau's Avatar
Get some brush-on rust converter (available at most hardware and auto shops) for starters. That will at least stop it rusting further and seal it until you work out your best course of action.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2006, 07:38 AM   #4
LTDHO
The one and only
LTDHO's Avatar
Hit it with a wire wheel and remove the rust, about 2mm of surrounding paint will be lost too. Then paint in primer and some colour. Use the closest colour match.
This will do until you have more cash and will not look that bad.
Tuned by CVE Performance
Old 11-05-2006, 08:53 AM   #5
AshMan
Girrrrr!!!
AshMan's Avatar
As LTDHO said, use a wire wheel, or even a dremel or similar rotary tool with a wire wheel attatchment for the more fiddly areas.
Basically try and get rid of all the rust before you do anything else (undercoat, bog, paint etc.) otherwise it will leak through and you will have rust marks down the side of your car and it will look even more dodgy.
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2006, 09:00 AM   #6
frtmatt83
ANOTHER FORD DRIVER
the are some other rust spots show up on the boot lid and a couple of other place. Would this wire wheel work on them place to and what is a wire wheel.
matt
Old 12-05-2006, 06:24 AM   #7
fmc351
let it burn
Whats a wire wheel? This cant end well.
Circular wire brush, for use on a drill. If you take it back to bare metal (you will, it is already), youll need an etch primer, before the normal primer. Whatever you do, get some rust converter aswell, and use that before etch primer.
