31-05-2006, 03:08 PM | #1 | ||
The window switches (both front doors) on my 99 AU Futura do not work when I first enter the vehicle and start up, but will invariably operate the windows after about three or four minutes of running. This is the case regardless of whether I furiously switch the thing up and down or simply leave it alone. And it happens on both switches - when one starts then so does the other. I have been told by the dealer that it could be the switch contacts but this seems at odds with the time delay and the fact that it will work after a while whether or not I have jiggled it a lot. Has anyone out there experienced the same problem? :
31-05-2006, 03:25 PM | #2 | ||
Formally Kia Chaser
this still could be due to dodgy conections... take the seitches out, put a bit of fine sandpaper on them, and see if it makes any difference... if it does - problem solved, if not... you may have to go to an auto sparky to find out....
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
31-05-2006, 09:28 PM | #3 | ||
FTF Club Moderator
Here is the tech doc on how to remove your power window switches. http://fordforums.com.au/vbportal/mo...article&id=180
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
01-06-2006, 10:26 PM | #4 | ||
Thanks to all respondents - the problem was the contacts on the power window relay in the fuse panel under the dash - I removed and checked the driver side switches but no go - then jiggled the relay while engaging the switch in the 'up' position and bingo I had intermittent working - cleaned contacts on relay and all is sweet - both sides!.
thanks |
01-06-2006, 11:41 PM | #5 | ||
Walking with God
Glad you got it sorted!
GK
