Old 16-03-2005, 11:45 AM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default How hard to change the steering wheel?
Hi all
Hope this is in the correct section.
As my AUII has an air bag how hard is it to take the steering wheel off without the air bag going bang.
I'm thining about getting a XR6/6 leather wheel.
Is there a tech guide on what to do?
Uncle_Ken:gren:
Old 16-03-2005, 12:21 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
its very easy.
u'll need a special shaped tool to get the acual air bag off, its basically like a security torx bit only it has a 6 pointed star instead of a 5, ford should be able to loosen these for you for nothing.
you will also need a Torx T50 security bit to undo the actual steering wheel.
ford will tell u to disconnect the battery for 5 mins before unplugging the airbag, so do that (i don't, i do it straight away :P )
undo the 2 bolts (6 pointed star things) at the back of the steering wheel, these are hidden by 2 round covers.
the airbag will then slide forward and only be held on my wiring, you will have to unplug the airbag wiring and the horn wiring.
once the airbag is out of the way you will see the wiring for the stereo buttons/cruise control.
you will have to unhook the wiring from any clips and undo the 4 (or 2 if u only have stereo buttons) screws holding the buttons on.
once these are undone u should be able to manouvoure the buttons out of the way, if not and they're getting caught on the plastic shroud then just make sure they have a little bit of slack
Next you will have to undo the big Torx bit (T50) in the middle, undo that, take it out, then put it back in a few threads (this prevents the steering wheel whacking you in the face when u pull it off)
you should be able to then yank the steering wheel off (takes a lot of force)
hold onto both side of the steering wheel and pull while rocking from side to side, some come easy, some come off hard, once its off time to put the new one on
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 16-03-2005, 12:45 PM   #3
Uncle_Ken
Uncle_Ken's Avatar
Default Thanks
I don't have the tools so I might just go outto Narellan Spares (Sydney) and see if they will do it as part of the deal.
Knowing my luck I'd get half way through and things would go... :
As Clint Eastwood would say "A mans got to know his limitations"
Uncle_Ken
Old 16-03-2005, 02:23 PM   #4
LG
LG's Avatar
I got Ford to put my momo steering wheel on, and they only charged me $80, so its not too bad seeing as the Security piece/tool costs around $60.
Old 16-03-2005, 03:12 PM   #5
au-steve
fully *** turboooo
au-steve's Avatar
i got the torx bit for $45 from ford.
au-steve is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2005, 03:18 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
$80 :o
i simply purchased the T50 bit, its used on many other parts through out the car so worth having
mine was deffinately no where near those prices though, i got a whole torx bit kit and it was heaps cheaper then that.
Old 16-03-2005, 03:54 PM   #7
DivHunter
DivHunter's Avatar
shizer Ford charged me $38 so i just got them to do it as I don't plan on changing it again.
Speed cameras have changed the things we pay attention to and the things we regard as important. Instead of focusing on the dangers ahead, motorists feel that they have been relieved of responsibility for managing their own driving, and have ceded it instead to the mechanical intervention of the camera and other traffic signals.
DivHunter is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2005, 05:43 PM   #8
buickman
buickman
buickman's Avatar
I paid $33 from a ford dealer for the air bag removal tool. It seems there is no set price on parts and tools sold. It is a 10-15 minute job to remove and replace with the right tools.
buickman
Old 16-03-2005, 09:40 PM   #9
FAT69XT
I'm about to do the same- the AUII has only done 100K and the rubber on the wheel is already loose and you can twist it!
Got a nice leather one for it, Ford can put it on for me i think!
Cheers,
Matt
FAT69XT is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2005, 11:13 PM   #10
Peuty
Afterburner + skids =
Peuty's Avatar
EFFalcon, you will find that the 6 star piece that hold the airbag on is actually a 5 star piece on the AU's. And the bit holding the wheel on itself is the six piece.
Just finished changing mine over the other week.
Oo\===/oO
Peuty is online now   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 05:43 PM   #11
buickman
buickman
buickman's Avatar
Me thinks you should have purchased the air bag tool. Ford P/N301PR for $33 so as to remove your steering wheel. As you mentioned today things are not looking good on the repair front on the Fairmont. If they decide to write it off you might have trouble trying to get to the car to remove parts without buying the wreck back.
buickman
Old 17-03-2005, 06:42 PM   #12
DivHunter
DivHunter's Avatar
buickman
Nah it's all good the guys at Martins will swap anything over for me ;)
Old 18-03-2005, 08:46 AM   #13
EFFalcon
Last warning
EFFalcon's Avatar
Must have been a change from AUI -> AU II then.
AU I deffinately had the old style T50 holding the steering wheel on (ala EF/EL)
and the 6 point for the airbag.
Old 18-03-2005, 09:34 AM   #14
buickman
buickman
buickman's Avatar
No way my Ghia is a series 1 and has the 5 star airbag security bolts that requires the 301PR security tool. I acutully thought of removing the bolts with a small chisel & hammer then replacing with the e series T50 bolts.Which might be the case if you have seen a series 1 with the 6 sided bolts. All AU's & BA's have the 5 star sided bolts. The larger S/Wheel holding bolt is 6 star.
buickman
Old 18-03-2005, 09:38 AM   #15
RG
Back to Le Frenchy
RG's Avatar
I got mine changed over by a smash repairer for $20. Cheaper and quicker than ford.
Old 18-03-2005, 09:50 AM   #16
EFFalcon
Last warning
EFFalcon's Avatar
looks like some AU's copped Eseries parts then.
coz i deffinately removed the steering wheel bolt myself with the T50 bit, but the airbag ones werent going anywhere with the 6 point star.
i can get photos P
Old 07-05-2009, 10:32 PM   #17
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
i found the hole kit for $15 at cunno's and they fit better than the genuine ones from ford i got.
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2009, 10:53 PM   #18
mik
mik's Avatar
hmmm interesting, i tried several tool shops none had the torx bit but one said if i get a company letter head order he can get it in for me at a cost of $45.00 because its classed as a security bit : ,local ford dealer spares did`nt have one, after hours of mucking around i got the dremel out with little cutting disc and carefully cut a slot in the head of the torx bits and unscrewed them with a screw driver, replaced them with allen key bolts.
Old 08-05-2009, 12:00 AM   #19
lostdude
lostdude's Avatar
i got a small flat head screw driver, and filled away the middle of it.
worked like a charm
Prev: 98 Au forte :
Now: 05 Wrx
lostdude is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2009, 06:25 AM   #20
StealthAu
Originally Posted by Uncle_Ken
Hi all
Uncle_Ken:gren:
If you try a search you might come accross a few answers. I've even posted the part number for a set of 5 sided torx bits from Repco at around $20.
Old 08-05-2009, 06:27 AM   #21
Peuty
Peuty's Avatar
Good advice Brendan, but Uncle_Ken posted that in 2005...
Oo\===/oO
Old 08-05-2009, 12:18 PM   #22
StealthAu
Didn't read the date, either way he could of done a search and found the part numbers, I only posted them 2 years after he asked the question
Old 09-05-2009, 06:47 PM   #23
Uncle_Ken
Uncle_Ken's Avatar
Holy C@$p!!! thats a blast from the past...I've had the Momo on for ages. When I bought it from Macarthur spares (NSW).
I got them to swap if over for ...um I forgot how much LOL.
UK
Old 18-01-2010, 03:13 PM   #24
EgoFalcon
The Villan
EgoFalcon's Avatar
What is cunno's? and is it in NSW?
New addition! 2010 FG XR50 Turbo in Lightning Strike
The PX Ranger has arrived! XLT Metropolitean Grey
Previous Ride - 2007 BF MK II XR6 in Lightning Strike
EgoFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2010, 04:08 PM   #25
GK
Walking with God
GK's Avatar
Wink
Bit of a thread mine! LOL!
Just shows that there's nothing new under the sun! The same questions keep getting asked by each new batch of AUvians! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 18-01-2010, 06:00 PM   #26
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Cunningham's Warehouse. Not sure if they're in NSW or not. I tried Googling it to see, funny that the first result is for one of their main competitors, Cheap As Chips!
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2010, 06:33 PM   #27
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
this is good as info i gota buy the tools for my car i plan on doing a steering wheel swap this week
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2010, 02:05 AM   #28
scrivens
quarter pane
scrivens's Avatar
Originally Posted by Riksta
THE HACK: 1988 Mitsubishi Colt GXL Hatch - Limited Edition - Mighty 1.6L Engine - Every option a Colt could have had from factory!
An off-topic aside. My brother bought one of those new and had it for 20 years and 450,000+km. Apart from the usual points, plugs, filters and brakes the only thing ever needing replacement was one sump gasket. Even had the original water pump, clutch and so on. Travelled all over Australia in it as well as commuting from Lithgow to Newcastle and back every weekend for years. Amazing little car.
scrivens is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2010, 09:29 AM   #29
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Ugh....this thing has been brought back from the dead twice now LOL
We should have some sort of thread mining smily we can insert!!!
Old 17-12-2012, 05:26 PM   #30
CONGO MILLENNIUM
Default Re: How hard to change the steering whee?
IS there a special tool needed to unplug the yellow cagle/plug from the back of the air bag?
How is it unplugged?
CONGO MILLENNIUM is offline   Reply With Quote Multi-Quote with this Post
