21-07-2006, 07:41 PM | #1 | ||
Has anyone had trouble with water leak in AUIII into sedan boot?
Dont open much but been raining in perth and went to put something in boot today and found condensation...opened rear door and folded down rear seat looked through to boot and saw daylight between seal and boot lid...Has anyone had the same problem? Is it just the seal not seated properly or damaged or actual boot lid? Hasnt been in accident as far as i no all looks original..Is it a factory fault? only bought this car 8 months ago and was thinkin of takin to dealer with extended warranty...But been stuffed around before with dealer...The jack and tools are all rusted too... |
21-07-2006, 07:48 PM | #2 | ||
I think its a common thing with the AU's. Mine leaks in I think around the holes for the rear wing
21-07-2006, 08:15 PM | #3 | ||
Fordless
Has never happened to mine.
21-07-2006, 09:37 PM | #4 | ||
My 1st set of Wings!!!
Yeah mine does too, the rear wings the culprit alright. I think someone had posted the same question and there were various solutions. I might take mine off and stick some silicone round the legs, I know it won't last as someone else had done this which only turned out to be a quick fix and not permanent.
PROUD OWNER NAROOMA BLUE 2002 AUIII XR6 :sm_headba |
21-07-2006, 09:49 PM | #5 | ||
checked spoiler but has gaskets so isnt from there no condenastion on actual boot lid but on boot floor
21-07-2006, 09:56 PM | #6 | |||
21-07-2006, 10:02 PM | #7 | |||
AU1s leak from the electrical connection grommet which actually goes into the boot from the foot of the AU1 wing (and therefore, any AU2 S pac etc, IIRC). Sounds like the gap between the rear screen could be the culprit.
21-07-2006, 10:29 PM | #8 | |||
21-07-2006, 10:31 PM | #9 | ||
[QUOTE=JC]Any leaks in the mounting holes for the rear wing will see the water leak into the rain channel around the boot - iw water should not get in because of this.
AU1s leak from the electrical connection grommet which actually goes into the boot from the foot of the AU1 wing (and therefore, any AU2 S pac etc, IIRC). Sounds like the gap between the rear screen could be the culprit.[/QUOTE mine AUIII but doesnt explain why gap between boot seal and boot lid? |
21-07-2006, 10:32 PM | #10 | ||
im not happy with it
very ****sed i also have ebII xr6 has original seals etc and 13 years old and doesnt leak why 4 year old car leak |
21-07-2006, 10:34 PM | #11 | |||
21-07-2006, 10:36 PM | #12 | |||
21-07-2006, 10:47 PM | #13 | |||
when something like this shouldnt happen no excuses man any1 no fix...thinkin of replacing boot seal but doesnt fix its dollars wasted any1 actually fixed problem? |
21-07-2006, 11:04 PM | #14 | ||
boot seals do leak occasionally, another very common leak is through the number plate mounting lugs, especially when people fit their number plates with screws that are too long and puncture the back of the lug, which then lets the boot lid fill with water, which then leaks into the boot when its opened
22-07-2006, 09:23 AM | #15 | ||
Mine has a decent leak, but I cant work out where.
When it was really pooring on day, I got in the boot through the back seat (to avoid opening boot and letting water in) and looked/felt all around for water coming in... none. But other days there's a tonne of water in there, which has led me to conclude it happens when it's driven... but I am not sure and cant find any 'source'. |
22-07-2006, 10:32 AM | #16 | |||
RDP #181
Mine leaked in around the number plate mount points, hasnt been doing it recently.
26-07-2006, 08:58 PM | #17 | ||
Ferret
I found I had a leak from the hole where the electrical cables come out of the body (top right hand corner of boot aperture) to go into the bootlid. There is a rubber sleeve over the whole lot but it had popped out of the aforementioned hole. I bent the plastic lugs out a bit, stuffed it back into the hole and it hasn't leaked since.
28-07-2006, 07:39 PM | #18 | ||
Fuzzy Logic
mine leaks toooooooo damn it, changed the seal, fixed some of it, now leaking from otherside, havent figured out where yet
23-08-2006, 08:57 PM | #19 | ||
Does any1 no if there is an extended factory warranty on panel and paint?
i no this an old thread but i cracked the ****s with it today when i found 2 inches of water in tyre well (pretty substantial leak)..Its been raining heavy in perth..I showed some initiative and removed all boot trims, got in there with a torch and got the missus to spray over the boot and rear window..Guess how many seperate leaks i found? 4 how crap is this..seems to be 1 on either sides down behind rear quarter panel seems, 1 in right corner above tail light, this where i think most of it coming through as i could see a hole all the way through where the seems join...NO SEEM SEALER! how disguisting! hows that for build quality! How is this car ever gonnna stand the test of time!..Oh yeah and its starting to rust already in the well..The fourth leak is coming in over the top of the boot seal as i was doing this on a flat surface.. |
24-08-2006, 09:37 AM | #20 | |||
id be taking it to FORD see what they can do... otherwise get out the silicon. :evil_laug and get some new seals from wreckers or FORD good luck
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
24-08-2006, 09:48 AM | #21 | ||
Life's a Gas
My AUII had a boot leak when new. The original owner left some dockets from warranty work in the glovebox which indicated they had to apply silicon sealant somewhere or other.
The car hasn't leaked water into the boot while I've owned it. I don't have a wing. The car is in at the panelbeaters at the moment, and these dockets are still in the glove box. I'll have the car back in 2 weeks and I'll try and work out what exactly was done. |
24-08-2006, 08:57 PM | #22 | ||
Cheers abacus that would be a big help as then i can go to FORD with the fix and they can do it properly..I am the second owner iv only had the car for 9 months it was an ex county car so maybe last owner didnt give a **** or was never really in the weather..I dont have proper carport and at work its parked in car park in the elements..I have FORD sort of on the case at the moment but hard to get anything done.
04-09-2006, 04:57 PM | #23 | ||
Update
Took it to the ford dealer where i purchased it and they said isnt covered under extended warranty (first day iv had off in ages so i could get stuff done). Rang Ford australia there basically backing the dealer and no1 has offered to help fix fault at all, even though this fault has been there from day dote. Obviously the last owner didnt care, or couldnt be botherd fixing or maybe just wasnt aware. So i have inherited a factory fault and Ford doesnt care. Its not as if its going to cost Ford **** all to fix. Not happy with this situation as i have forked out good money for this car. So sadly im going to get it fixed properly by a panel beater and then going to to sell this peice of ****! Last newish or new ford ill ever buy! : |
04-09-2006, 05:35 PM | #24 | |||
FRIKA
Sorry to hear the bad news. i do feel for you especially since you just purchased it.
New 2008 LV Focus XR5 in Performance Blue
04-09-2006, 08:32 PM | #25 | ||
I have AU11 and cant find whereit comes from i have sealed everything and craweld inside in the rain but still cant find it
Leaks water when you lift the boot lid |
04-09-2006, 08:58 PM | #26 | ||
Audi S3
mine gets water in the boot lock/latch thing sometimes/somehow. but it doesnt phase me.
05-09-2006, 12:22 AM | #27 | |||
Fantastic Plastic
As originally mentioned earlier about that gap seen at the back of the boot near the bottom of rear window ( seen with the back seat down ) , check your bolts on the hinges and make sure they are not loose , alsmost sounds like the boot has tilted down towards the bumper-bar and up and away from the seal near the window / could of maybe happened from closing the boot heaps , the force of pulling it down might of put it out a bit . Maybe try loosen 1 bolt on either side of the boot hinges on the boot ( only loosen 1 on each side , the lower bolts closer to the body of the car ) , then with the boot up , push it up and towards the front of the car just that little bit futher than where it is sitting then re-tighten the bolts , this will tilt the back of the boot down near the window (closing the gap hopefully ) , but will also raise the boot off the rear bumber a bit . gl . By right you shouldnt have this gap , so it sounds like something is out of whack or misaligned .
05-09-2006, 12:49 AM | #28 | ||
Make sure the bolts for the bootlid handle are sealed too.
05-09-2006, 09:52 AM | #29 | |||
buickman
26-09-2006, 08:14 PM | #30 | ||
i have to make apologies for some comments i have mde about this problem. My car is at the panel shop at moment nad it turns out that the leak is actually coming through the rear windscreen. Apparantly the screen has been out and not resealed correctly. On further investigation they found that it has actually had a new quarter panel skin fitted sometime in its life, so thats why the screen was removed so therfore the hole between panel seams is also due to poor fitting. At first site they had no idea it had a repair because the actuall finished job wsnt bad except these problems. So will be fixed correctly by the end of the week and will be better than before. So there u go u never no wot u got even when the dealer so calls only buying accident free vehicles to sell. Dissapointing its had such a major repair before... So there u go sorry if i offended any1 and FORD as i got up them initially..So if any1 else has a leak that cant be found check windcreen and for old repairs :
