Old 24-07-2006, 08:50 PM   #1
Junkz0r
Junkz0r's Avatar
Default Question about EB II Power Steering drive
Hi folks.
I have a 92 EB series II with a 4.0, ABS, MPFI etc etc.
Over the weekend I replaced the power steering pump as my old one was leaking onto the alternator (damnit!). The power steering pump went on without a hitch and has completely new fluid and doesn't leak a drip.
The question I have however is this. The belt that was on the car for the PS pump is a Bosch 11A1180 (11mm wide and 1180mm diameter I assume?) and needs replacing to complete the new pump install (belts pretty stuffed).
Now here is my dilemma: Bosch states that the PS belt for an EB 4.0l (1991-93) is a 11A1195. The belt that is on it is the above stated 11A1180 and the top idler pully is at the far end of its adjustment. Obviously the 1195mm diameter belt wound up being TOO BIG, but the Bosch belt manual claims it's the correct item. Curiously, Bosch also states that the belt for a 3.9 EA is the 11A1155 and i'm not sure that would be long enough.
Any ideas as to why this is so? Is the Bosch catalogue incorrect?
Input would be much appreciated thank you.
Junkz0r is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 09:10 PM   #2
smally289
growing up is optional
smally289's Avatar
Have come across this before at work. Our Bosch catalogue is just as wrong as yours!!
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 09:43 PM   #3
YLDTRK
Formerly GTP075
YLDTRK's Avatar
might be a stretching issue?
13 PX WILDTRAK brand new wheels and tyres for sale Pm me
YLDTRK is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:15 PM   #4
XRated
Shoot.
XRated's Avatar
I had the EXACT same problem!!!!!!! Just get the next two(?) sizes down (I think the catalogue lists it under EA55 like you mentioned). I'm guessing the pulley size is smaller (same as EA) on that particular brand of pump; hence needing an EA belt.
PS: I had this issue after replacing the water-pump.
20V Turbo
Old 25-07-2006, 09:45 AM   #5
Junkz0r
Junkz0r's Avatar
Thanks for the input guys.
So I'm guessing the 1195 is too long, the 1180 thats on it currently (as stretched as it likely is) doesn't give anymore adjustment on the idler...
Should I go and buy an 11A1170 belt?
Old 25-07-2006, 11:47 AM   #6
XRated
Shoot.
XRated's Avatar
Just go try a few different ones until it's right. Supercrap is usually happy to let you swap and change.
20V Turbo
