28-07-2006, 01:04 PM | #1 | ||
FirstOnRaceDay
Ok does anyone know if you can change the offset to AU from pre-AU??
And how much would it cost ESTIMATE! Coz I am sick of hunting around for f k n rims! Every were I go no sorry we only have one kind(the worst looking mag in the world) and then they say you will have to get them made from scratch... : I am just doing my head in so can someone help Cheers James. |
28-07-2006, 01:29 PM | #2 | ||
PM me if you want
You cannot change the offset.
3 piece rims are the exception as you can get new centres with correct offset. Pre AU is +6 Post AU is +35
28-07-2006, 01:58 PM | #3 | ||
15 inch stokies are the right offset;)
28-07-2006, 03:47 PM | #4 | |||
Shoot.
20V Turbo |
28-07-2006, 03:48 PM | #5 | ||
Two > One
AU spec offset can be done by AU front suspension transplant and AU live rear end.
28-07-2006, 03:59 PM | #6 | |||
PM me if you want
28-07-2006, 05:22 PM | #7 | ||
Walkinshaw - has anyone ever done this? I was going to go to the wreckers tomorrow and have a damn good look at the respective EB/AU setups, as I'm looking for a set of rims and it's impossible ti find anything bigger than 17x8, unless I get simmons which will be about $2500 - not cool.
Is there welding involved or just carefull matching of parts? |
28-07-2006, 06:17 PM | #8 | ||
ive looked at it, dont think it is possible, cant think of the reasons right now, hard to think after a few pale ales
EB 4L, 8.4:1, GT3540r, Greenslade Engineering exhaust manifold and plenum chamber, 90mm throttle, 600x300x100 cooler, Surecam custom turbo grind, autronic SM4, siemens 72lb, Crane HI-6, LX-92, Innovate LM-1, Turbosmart Street Reg, bosch 044, turbosmart 48mm w/gate and v-port BOV. 335.8rwkw 1bar |
28-07-2006, 07:06 PM | #9 | |||
Location: Under the bonnet, trying to keep as clean as above!
very interesting..... you have my attention. what sorta $ are we looking at here? |
28-07-2006, 07:09 PM | #10 | ||
Last warning
an EA at winton had AU front suspension & brakes.
basically modified the kframe to accept the AU lower control arms and radius rods, the rest bolted straight in.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
29-07-2006, 12:23 AM | #11 | ||
The Guy You Love To Hate
Someone was looking at using R32 skyline susp parts and using r32 GTR brake and hub setup with suitabel offset too obviously
29-07-2006, 09:11 AM | #12 | |||
Back to Le Frenchy
Why does everyone seem to have so much trouble finding rims in the E-series offset. When I was looking there were about 8 different styles in 18" and I wasn't even trying that hard, just at beaurepairs and bob-jane.
29-07-2006, 10:02 AM | #13 | ||
Wasnt NZ going to do something like this to his car.. or am i trippin
29-07-2006, 11:14 AM | #14 | |||
Shoot.
Nah he's just a busy man.
20V Turbo |
29-07-2006, 11:18 AM | #15 | ||
Two > One
There is a wrecker who will do an AU2 front end conversion to EA-D's (and presumably EF-L's). I havent heard anything on the cost of this conversion though.
The biggest drawback with Au setup is the lack of dish you can get on your rims. Actualy...hrmmmm.... AU2 front end, 18x8.5 and run an Eseries rear diff and get some 18x10.5's in there
29-07-2006, 11:18 AM | #16 | |||
29-07-2006, 06:14 PM | #17 | ||
Well I went to the wreckers today for a look at some AUs.
I could only find a couple of series 1 AUs, the 2 and 3 might be different as they have different brakes, but it seems unless you do some serious K-frame modding and are a very competant welder/fabricator it's not going to happen. The main problem is that on the E-series cars the bottom ball joint is attached to the strut that the brake rotor etc is attached to, but on the AU it is attached to the lower control arm. If they both had the ball joint in the same place then it would be easy, but they don't, so its poo. AU diff looks like it should bolt straight in though... |
29-07-2006, 07:05 PM | #18 | ||
if i knew what had to be done it would be no problem at all. all i would have to do is con my old man into doing it (boiler maker for 36yrs).
29-07-2006, 07:13 PM | #19 | |||
Last warning
thats pretty much the case Rollin, the S2 and S3 are the same, fairly hefty mods required, but it can be done. the only person i've seen thats done full Kframe from an AU into an eseries actually cut the chassis rails and welded in the AU parts, it worked but still not exactly simple :P
29-07-2006, 07:25 PM | #20 | ||
Just get some 3 piece wheels or buy an AU ;)
30-07-2006, 12:42 PM | #21 | ||
Formerly GTP075
adaptor plates are the way to go. i've had mine for 3 years... not one drama
13 PX WILDTRAK brand new wheels and tyres for sale Pm me |
30-07-2006, 12:55 PM | #22 | |||
likes falcon's
www.carhubsales.com.au |
30-07-2006, 03:16 PM | #23 | |||
Shoot.
20V Turbo |
30-07-2006, 04:08 PM | #24 | |||
Maybe you have a different type to theirs? I'm interested... |
30-07-2006, 05:28 PM | #25 | |||
DFDFDF
All adapters are basically the same.. DODGY AND ILLEGAL.. LOL.. Just stop being so picky bout your rims.. and dont just go to your standard shops.. ring the manufacturer and ask what they have to suit your car.. then when you find a style you like head to your local ripoff.. i mean tyre dealer and get them in.. thats how i got my rims.. minus the tyre dealer part.. LOL.. I think i came across atleast 20 different rims in 18" and atleast 10 in 19"+.. admittedly some do look similar but most of them suit the e series cars.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
01-08-2006, 01:51 PM | #26 | ||
FirstOnRaceDay
Yeah But I want god-damn 20's... DOes any one have any pics Og simmons.
01-08-2006, 06:56 PM | #27 | ||
DFDFDF
Pitty that putting 20's on a e series is illegal in NSW.. Good luck with it though mate..
Cheers, Nik
01-08-2006, 07:02 PM | #28 | |||
@jas_23_
01-08-2006, 07:08 PM | #29 | |||
I also don't want anything that could be called "chromies" because thats not what my car is about - If other people want to make the outsides of their cars look hot and not do the drivetrain/suspension then im cool with that, but it's not what I want. I have emailed approximately 11ty billion rim manufacturers about wheels, none of them have anything in the size I want, and I really don't like the design of most of the smaller (read: width) rims. GO > Show |
01-08-2006, 07:13 PM | #30 | ||
DFDFDF
My error.. i was always lead to believe in nsw you could not go larger than 2".. after checking out the RTA website.. i was wrong.. my apologies..
I still dont know why the cops always question me regarding being 5" bigger than stock when i am in NSW.. maybe they dont realise the rules have changed or something.. Cheers, Nik
