Old 30-08-2006, 09:21 PM   #1
TICKFORD_XR6
TICKFORD_XR6's Avatar
Default AU radiator fans on EB
hey
how good are the twin AU radiator fans?
r they worth buying?
wil they go on an EB?
Damon
TICKFORD_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 09:27 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
anything will fit with the right modification and imagination
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 09:30 PM   #3
TICKFORD_XR6
so im guessing it wont go straight on ...?
Old 30-08-2006, 09:38 PM   #4
Psycho Chicken
Psycho Chicken's Avatar
Just get EL ones. AU will fit with some fiddling. EL will bolt straight in.
Old 30-08-2006, 09:48 PM   #5
TICKFORD_XR6
o ok
do they do anything anyway?
my mate reckons u gain more power ...
is this tru :S
Old 30-08-2006, 09:53 PM   #6
ssb2005
Scrubber Racing Team
ssb2005's Avatar
i hear between 5-15 hp gain depending on size of original fan
www.cardomain.com/id/ssb2005
2001 TM Racing 250 2T enduro.
1992 Falcon S XR-6 161+Kw's zorst, chip, tickford engine and ecu
1984 AB GSR Cordia tidy up time. DASH is here!! future track weapon
1973 Yamaha RD 250 project cafe racer
ssb2005 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 10:04 PM   #7
TICKFORD_XR6
o ok kool
so.... the EF fans will b the same as the EL fans?
cause il get them cheaper if i buy the EF ones...
(sorry im not that good with cars haha)
Old 30-08-2006, 10:06 PM   #8
Psycho Chicken
You don't anywhere near that much power. Maybe 4-5 rwkw tops. Just sounds better in my book. Should rev a bit better.
EF will bolt straight on but run slightly different to EL fans. EL are the easiest to wire up.
Old 30-08-2006, 10:12 PM   #9
TICKFORD_XR6
done deal
im buyin one haha
thanx
Old 31-08-2006, 02:54 AM   #10
blownba
LPG Forum Moderator
blownba's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all his assistance helping members with their LPG issues.
mmm. I dont think you'd get much gain . A good clutch fan should never be creating resistance at big revs anyway. If it is your hub is stuffed. Then what about the alternator load increasing cause it has to power those two fans. They draw heaps of current on high speed. Then you have to wire em up with a thermo switch and figure out how to achieve the low speed and high speeds make sure they have good power supplies with fuses or fusible links.
I reckon its not worth it like I said a clutch fan does not really offer much resistance at full throttle anyways or at cruise for that matter. It should only lock up when the heat coming through the radiator is hot enough to make the bi-metallic spring in the front of the hub lock up the oil passage inside it.
It'd be interesting if someone could do a power run on the dyno with the fan on then unscrew it and run again. Lets guess how much it'd be. Cause I really have no idea.
blownba is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2006, 08:12 AM   #11
smally289
growing up is optional
smally289's Avatar
AU fans arent wide enough for your radiator. EF /EL ones will be a perfect fit.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2006, 09:01 AM   #12
TICKFORD_XR6
if any one in QLD knows a good cheap dyno place tell me and i might do it cause iv been meaning to go to one :Reverend:
next question.... how to install it..?
Damon
Old 01-09-2006, 01:34 AM   #13
fmc351
let it burn
Redcliffe Dyno and Performance are a site sponsor.
Links at the top of every page (RDP)
Old 01-09-2006, 01:49 AM   #14
XR Martin
XR Martin's Avatar
Clutch fans especially on the Falcon are terrible. You'd be amazed at how much smoother the car runs without it, and revs so much easier and further. The car is much quieter at idle, and on dirt you dont create a giant dust storm under the car.
As for power I didnt really notice anything, but like I said it did rev smoother.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 01-09-2006, 02:58 AM   #15
Rmyers
Does Steve have a car?
Rmyers's Avatar
I have AU thermo's in my EA. The best way i found to fit them was to install the upside down :P
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2006, 09:33 AM   #16
bArNsY
bArNsY's Avatar
I have wired my thermos up so they take 5 mins to pull out, put the clutch fan back in. Might test this at the Geelong dyno day....i have noticed the power difference (lol i was running a 5 blade EA clutch fan beforehand tho)...interesting to see the results
Cheers Adam
The Old:
1993 ED Fairmont
1994 ED Futura Classic manual,
2004 BA MkII XR6 Turbo
2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing)
2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit)
2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade)
The New:
2023 UB Everest Trend 4WD
bArNsY is offline   Reply With Quote Multi-Quote with this Post
