Old 31-08-2006, 07:38 PM   #1
ebxr8_50ho
now EFXR65spd
ebxr8_50ho's Avatar
Question Gearbox swap
My transmission isn't very happy and I want to get another from the wreckers because its cheaper than the $2700 rebuild. If I was to buy for example an AU V8 tranny, or any other model V8, will it bolt straight in to the EB, or will I have to track down an EB box?
Any info will be appreciated
People dont even look at BA GT's anymore, there like aresholes, everyones got one.
ebxr8_50ho is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2006, 08:37 PM   #2
mcflux
mcflux's Avatar
$2700 rebuild? :S
EB-AU BTR *should* bolt on, and I believe the EF-AU BTRs still have a separate TCM. Same bellhousing, input shaft size/length, etc. Keep your shifter & linkages though, the AU's setup is different in this respect.
Old 31-08-2006, 08:42 PM   #3
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
I know that the bottom bolts on the bellhousing of an EA-EL BTR don't line up with the AU engine. You can only tighten the middle and 2 top bolts.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2006, 11:30 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Keep in mind we're talking about V8's. They bolt straight up EB-AU.
AU's don't have a seperate TCM, as they use a proper EEC-V.
Keep in mine EF2 and EL transmissions won't have dipsticks. Not that big a problem, unless the trans leaks at all. I don't know where you got the $2700 quote from, but you can get BTR's rebuilt to handle 450rwkw for around that price...
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2006, 10:23 AM   #5
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
sorry to steal the thread but would a EL XR6 5speed bolt in where my 4speed auto lives in the EF? and wot do$h would i be looking at to own it? backyard install...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
