Old 21-09-2006, 08:29 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default 1995 Ford Fairmont GHIA V8 any major issues?
To the E-Series Knowledge Machine
I am thinking about buying a 1995 Ford Fairmont GHIA V8 and was wondering if there was anything that is an issue with these cars.
Also has anyone heard of "hi-tech" extractors for this car?
Did all Ghias EF to EL come with interior chrome handles?
I heard a rumour that the V8's auto's are not as strong as the 6cyl auto's - is this true?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 09:28 PM   #2
efgiar
rofl copter
efgiar's Avatar
yes ghias came with chrome handles, hi-tech are just another brand, like pacies, lukey etc etc. unsure on the autos but i presume they are as stronge as each other? same internals.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 09:56 PM   #3
niko
likes falcon's
niko's Avatar
arn't they're stronger than the 6 autos, they cop more torque?
hitech are a vic made header ;)
www.carhubsales.com.au
Old 21-09-2006, 10:20 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
i highly doubt the I6 autos are stronger then V8 ones, i'd be inclined to say the opposite.
i think the V8 valve body is better.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 22-09-2006, 09:46 AM   #5
mcflux
mcflux's Avatar
V8 autos have a slightly different stall speed I believe (slightly higher, but SFA), and perhaps some better quality bands (once again, not too much better).
Old 22-09-2006, 11:53 AM   #6
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
V8 BTR's use steel check valves, and a lot more steel in the valvebody construction than an I6 BTR. When trans shops rebuild I6 BTR's, first thing they do is put a V8 valvebody and check valves in.
There's nothing too specific to check, same with all E-Series really. Brakes, transmission, electrics, power windows.
Being a V8, there's one other major issue that needs attention.. A total lack of power, but that's easily fixed with a manifold and some heads ;)
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2006, 12:51 PM   #7
Sorted
Sorted's Avatar
I see you have all this done to your EF.
Guess you would know if there are any major issues - how many k's on yours?
Tuned by DYNOMOTIVE
Old 22-09-2006, 06:15 PM   #8
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I bought the car with about 125,000km on it nearly 4 years ago, it has 215,000km on it now.
The main problems I've had with it was burning the C4 hub in the trans at about 190k, broken LF window regulator, exploded both radiator side tanks (during a burnout), the blend door motor was shagged when I bought the car, and I've killed 2 fuel pumps since I've had it. The 2nd fuel pump was my doing, the in-tank pump uses the petrol around it to cool down, if you run the tank low they run hotter and burn out quicker.
I service the car every 5,000km, and maintain it fairly well, but I'm the first to admit I do drive it hard, and cars don't last forever.
The only fairly common problem with the 5.0 is the timing case corroding and pumping coolant into the oil, but apart from that, with regular servicing, they will last longer than the rest of the car. I've seen a fair few threads made on people needing new MAF sensors lately as well.
Old 22-09-2006, 07:33 PM   #9
SVT8
SVT8's Avatar
the v8's are great they keep going and going and going. All internals of the 8's last forever but sometimes there are problems (depends on how you drive it and condition). The main problems that i have found in my v8 are that many connections, such as piping, seals etc are very weak but they are easily replaced.
Trans will last a while depending on the amount of stress its under. But otherwise if its regulary service it will be one of the most reliable cars ever.
SVT8
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2006, 11:23 PM   #10
Sorted
Sorted's Avatar
Seems they are pretty much bullet proof
Main concern is the V8 engine - everything else would be the same as my current EF Monty
Tuned by DYNOMOTIVE
