Old 05-09-2007, 09:37 PM   #1
st33l3y
Pursuit #144
st33l3y's Avatar
Default Loss of power in AU1
hey people, need some help. I recently had extractors installed onto my AU1 falcon. Now I have actually experienced a loss in power and worse fuel economy. The bloke who installed them told me he installed the cat in reverse because it wouldn't fit on with the extractors. The exhaust now makes a sort of raspy note coming from around where the cat is. Is this the problem and should I just go for an aftermarket unit? Any help would be greatly appreciated....
st33l3y is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 11:38 PM   #2
nikos
mezzo forte
Maybe he rattled and banged the cat around during installation, which could have knocked some bits loose if it was already old. Loss of power and fuel economy points to the cat, I doubt it would be the new pipes lol!
Cheers Nic
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 12:27 AM   #3
TwistedEL
TwistedEL's Avatar
Yeah I'd unbolt the cat convertor and see if it has the rattles
Old 06-09-2007, 08:50 AM   #4
StealthAu
It's not ment to be installed backwards. Take it to someone with half a brain and get it sorted.
Old 06-09-2007, 09:25 AM   #5
Eu-GenixX
Eu-GenixX's Avatar
the sheer mentality of some of these 'mechanics' out there absolutely astounds me....
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 07:44 AM   #6
st33l3y
Pursuit #144
st33l3y's Avatar
I know, this is the local bloke that everyone uses, so I expect him to know what he's doing. I went and saw him yesterday and he reckons he'll fit a new hi-flow cat for $250. It's illegal not to have one, isn't it?
Old 07-09-2007, 10:44 AM   #7
Eu-GenixX
Eu-GenixX's Avatar
very illegal.. and very bad for environment and peoples health...
Old 07-09-2007, 11:08 AM   #8
FGII-XR6
FGII-XR6's Avatar
you must have a cat as mentioned above and removing it will not give you any gains over a high flow cat just losses to your wallet. as I understand it the fines for removing a cat are quite high. It's just not worth the risk. just a hint though if the cat was fine when you took the car in it sounds like the mechanic stuffed up he certinatly shouldn't have reversed it. i'd be hitting him up to at least partly cover the cost
Old 07-09-2007, 11:34 AM   #9
StealthAu
Well clearly he dosn't know jack. fitting the cat backwards will give all the simtoms you mentioned, and all mechanics/exhaust fitters should be well aware of this. Also there are 100's of AU's that have had extractors with the stoc exhaust, so I'm guessing the only reason it needed to be fitted backwards is to get you back in to spend more money.
Old 07-09-2007, 02:34 PM   #10
nutter_x
Nange Road Warrior
nutter_x's Avatar
So I take it you want to hold off on that drag you wanted then? :
nutter_x is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 04:44 PM   #11
st33l3y
Pursuit #144
st33l3y's Avatar
Righto, got the new cat installed and holy .... this car rocks... now we can drag, Dave...
