06-09-2007, 10:57 AM | #1 | ||
AUII XR8 Ute
My mate has an auIII ute and it leaks water near the bottom of the steering colum when it rains. It is obviusly running down from the firewall or windscreen but it doest seem to stand out.
Any leads???
AUII XR8 UTE........std but big rims!! |
06-09-2007, 01:29 PM | #2 | ||
Windscreens are a known problem, pay the 20 extra and get O'briens to pull it out and re-seal. they give a lifetime waranty on leaks.
06-09-2007, 02:23 PM | #3 | |||
BOSS Pilot
Common problem with the AU. Its most likely coming through the firewall somewhere. Mine does it, and Ive heard of so many others that do it aswell
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
06-09-2007, 09:00 PM | #4 | ||
AUII XR8 Ute
Thanks.I will tell him he Might as well get the windscreen resealed as a starting option.
07-09-2007, 07:16 AM | #5 | ||
Yep mine does it as well.
08-09-2007, 08:18 PM | #6 | ||
yep mine does it aswell, gives me the sh**s, but as it hassnt rained much dont notice it, still pain in the but tho
08-09-2007, 11:09 PM | #7 | ||
XB in parts...
Is it a manual ?
If so, they're known to suffer from cracked pedal boxes. The firewall can also crack. Get these two bits checked out. I had mine fixed a short time back.
08-09-2007, 11:42 PM | #8 | ||
yep my Au3 sedan has just started to leak water from under the dash above the ecu near the duct on the passenger side when it rains heavy.The water drips on to the floor mat when im driving.Any ideas.
09-09-2007, 03:06 AM | #9 | ||
au=gold
How much water do people get in just for curiosity. And where's a good place to seal it. Cos my drivers side fills up pretty nicely
09-09-2007, 09:32 AM | #10 | ||
yep my ute leak aswell keep driping down on my foot near the clutch pedal
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
09-09-2007, 09:34 AM | #11 | ||
Just slidin'
When I go around sharp lefts in the rain, I get a dribble on my foot. Always freaks the hell outta me, but to answer the question, its normal, just an AU thing.
MD Mondeo - For the family
09-09-2007, 09:37 AM | #12 | ||
Right out sideways
yes my ute does it too, sedan doesnt though
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
09-09-2007, 09:49 AM | #13 | ||||
BOSS Pilot
09-09-2007, 12:10 PM | #14 | |||
au=gold
09-09-2007, 12:18 PM | #15 | ||
my au xr8 manual sedan does it too. Might have to check the pedal box....
09-09-2007, 10:45 PM | #16 | ||
Formerly MR BAXR6t
yea just noticed the same problem with my series II
10-09-2007, 05:15 AM | #17 | ||
my Au xr8 does it, comming from up under the dash near steering somewhere. not near the pedal box, really annoying
10-09-2007, 10:54 AM | #18 | ||
Add two more to the list. A AU2 XR6 ute and AU2 XR8 rebel. Both man. Only leaks under acceleration on to our right foot, from above the brake. Have looked but can't find the leak. will chack the windsceen and pedel box later.
10-09-2007, 12:09 PM | #19 | ||
XB in parts...
If it's not the pedal box, it's could be
- a crack in the firewall, - a drip where the wiring goes thru (the firewall) and the rubber gromet thing is loose (causing leaks) or - the heater hose leaking. These seem to be the most common AU water related problems that I've heard about.
11-09-2007, 08:34 PM | #20 | ||
AUII XR8 Ute
Il get him to check every area mentioned and try and eliminate it.
Thanks.
10-03-2011, 05:45 PM | #21 | ||
so have any of you had the problems fixed
10-03-2011, 05:58 PM | #22 | ||
Are the Supercars on yet?
http://www.fordforums.com.au/showthread.php?t=11220972
This should hopefully solve ur problems, i did the same to mine
A Ford win is a good win! V8 dreamteam 1st: 2012, 2021 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
10-03-2011, 06:44 PM | #23 | ||
thanks for that looks like that might b the problem will try it and let ya all know thanks again
12-03-2011, 01:29 PM | #24 | ||
My ute used to leak water on my feet when it rained heavy.
Took the advice of the above link and haven't had the problem since.
AU111 XR6 Ute, VCT, Leather, Manual. |
12-03-2011, 02:16 PM | #25 | ||
its has worked for me too thanks again hope i can help u out next time
12-03-2011, 04:16 PM | #26 | ||
Agree with the last link. Followed it and now can get into my car in winter without a half inch of water in the footwell...
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
12-03-2011, 09:46 PM | #27 | ||
not here much anymore
I actually did mine yesterday and it worked a treat.
2024 F150 XLT
