Old 06-09-2007, 07:56 PM   #1
psi
Unhappy Boot lid stuck
Hi
My boot lid won't open, I can hear the actuator trying to open it, so it's not electrical. I can't get into the boot because it is dual fuel, but I've taken a speaker out and have found the manual boot release but that seems to be stuck also. Any ideas? Big crow bar or oxy?
psi is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 07:59 PM   #2
sly
Sly like a G6
sly's Avatar
Has it rained near you lately? My tailgate always sticks after rain and needs a big pull to open. Maybe get a helper to press your button while you pull on the bootlid.
Sleeper, anyone?
Old 06-09-2007, 08:25 PM   #3
psi
Yeah I tried that, no luck. It's as if the latch is jammed,if it wasn't for the lpg tank I could probably get in with a screwdriver or something and force it, can't do much through the speaker hole though.
Old 06-09-2007, 08:59 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
I'm still investigating, but I think I know why mine's stuck...
Old 06-09-2007, 10:37 PM   #5
peterban
AULTD
peterban's Avatar
Thats a shame to see a well looked after car have that happen.
I suppose it is one way to get into the boot though!!!!
How did you end up with a white piece across the boot instead of the red, have you been raiding LTD's??
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 09:43 AM   #6
private9
private9's Avatar
Still can't get into the boot though! I believe the previous owner added the LTD garnish, not that it's much good now though!
Old 07-09-2007, 10:57 AM   #7
StealthAu
Just keep yanking the manual release while someone pushes down and pulls up on the boot lid (ussing alot of force). After 10 minutes if still no joy your oxy idea sounds like the next path of attack
Old 07-09-2007, 11:09 AM   #8
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
it will be a cable loose in the auto release,
hop in the boot via rear seats.. and there is a cable that joints the lock to the solenoid.
yank the cable
BF Futura Dedicated E-GAS w/Ghia bling
Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM
BeStRaFe is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 11:40 AM   #9
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
ummm. i hate to put a spanner in the works but i wouldnt be using an oxy near AN LPG TANK : . a crowbar sounds better
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 11:49 AM   #10
FGII-XR6
FGII-XR6's Avatar
this is locking the stable door after the horse has bolted i know but the factory dual fule cars had a longer emergency release cable. it runs to a spot just behind the seat. I just bought one for mine but i'm yet to fit it. only cost about $40
Old 07-09-2007, 12:19 PM   #11
private9
private9's Avatar
yank the cable
I think he has something little, like an LPG tank in the way!
Old 07-09-2007, 04:36 PM   #12
Burley
CRE.87V
hey mate mine did this a few weeks ago...wen i popped the boot i had to like push down, not to shut and then pulled up...opened then....then i sprayed the whole rubber with silican spray...never had a problem since
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 08:18 PM   #13
psi
Default Got It!
Finally managed to get the boot open, here's how I did it in case this happens to anyone else out there.
I pulled both speakers out, got my daughter to point a camcorder on Night shot mode through one speaker hole so I could see what I was doing on a 14 inch TV in the middle of the back seat, that made it a lot easier! after having no luck with the cable i used a long flat bladed screw driver with a 10mm socket on the end to undo the two nuts holding the latch mechanism to the boot lid, then used a broom handle with a solid hook on the end to wrench the latch off. Ripped open the boot lid, luckily the plug disconnected without damage, the cable was out of position anyway because of my previous efforts. a long arm required! I was up to the armpit and my head was wedged sideways up on the parcel shelf.
I found corrugated cardboard jamming up the latch, pulled it all out, works a
treat now!
I also extended the boot release cable and brought it over the lpg tank although it would not have made a difference in this case, it could be handy in future.
Old 08-09-2007, 08:25 PM   #14
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
i'm loving the dedication and ingenuity!
MacGyver has nothing on you
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 09:56 PM   #15
private9
private9's Avatar
Great effort mate! By that stage I think I'd be out there with the crowbar!
Old 09-09-2007, 10:38 PM   #16
v8falconsrule
Blue ~oval~ Blooded!!!
v8falconsrule's Avatar
had a similar trouble with mine peice of carboard got caught in the latch. had to unload 4 people's worth of luggage through the rear seats, coz my mate reefed on the manual release and frigged it. had to crawl in and un-bolt the latch.
thankfully mine is petrol only though.
Give me fuel, give me fire!
50th Anniv G6E Turbo in Sensation
Cobalt blue 94 ED XR8 Sprint- resto/ project
v8falconsrule is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 12:04 AM   #17
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Plastic bags and airport luggage tags are good for jamming in there too
Jastel is offline   Reply With Quote Multi-Quote with this Post
