Old 10-10-2006, 08:11 AM   #1
bab
Default Coolant Leak From Ef
I Have Small Green Coolant Leak What Seems To Be Coming From Back Of Motor Approximately Where The Firewall Is,it Is Not From The Air Con Overflow Pipe,it Seems To Drop Onto Floor Below Where The Front Of The Centre Consol Is,any Help Appreciated
bab is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 10:22 AM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Could be:
Headgasket, heater tap, water gallery, heater hoses, etc.
Take it to a mechanic and get him to pressure test it on a hoist.
That's the only way to know for sure.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 10:55 AM   #3
SVT8
SVT8's Avatar
yeh the pressure test will find exactly were the leak is, then its just a matter of fixing the problem.
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 02:32 PM   #4
Sammy B
Have A Swell Day
Sammy B's Avatar
Yeah i've got the same problem atm on an EL near the water pump, just bought a new one + radiator.
Sammy B is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 02:37 PM   #5
vigilante000
/\/\etaL and V8s -Awesome
vigilante000's Avatar
If its inside the car, its probably a heater box that has cracked open. Are you noticing if you front windscreen is fogging up a bit?
If its from outside under the car, have a look at the rear welsh plug, nasty!
ViGiLaNtE351
Nothing Sounds Better Than A V8
BA XR8 MKII
EB Falcon ThermoFan Conversion
http://www.fordforums.com.au/showthr...t=vigilante000
BA Falcon ICC Speaker Wiring
http://www.fordforums.com.au/showthread.php?t=11342785
BA Wiper Motor in XE
http://www.fordforums.com.au/showthr...=1#post5393955
vigilante000 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 11:26 AM   #6
bab
THANKS FOR HELP GUYS BUT I THINK I HAVE FOUND LEAK,IT APPEARS BELOW SPARK PLUG ON LAST CYLINDER NEAR FIREWALL WHERE HEAD MEETS BLOCK AND TRICLES DOWN FROM THERE,SOMEONE SAID IT MIGHT BE HEAD OR COULD BE FROM INTAKE MANIFOLD,IT IS VERY MINOR LEAK ON TO GROUND SO IS IT WORTH WORRYING ABOUT AND IF IT IS HEAD WOULD I GET SOME TIME OUT OF IT BEFORE NEEDING REPAIR,CAR HAS DONE 127000 K's
Old 11-10-2006, 11:37 AM   #7
white_XR8
I have the same problem on my ef, I got one welsh plu repaired wich cost around $50 - 80 but now i have a leak somewhere else aswell i will get it checked out today, hopefully its not a head gasket just a welsh plug :S
white_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 07:46 PM   #8
DNKPWR
DNKPWR's Avatar
Heater hose.. hopefull not the head gasket!!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
