20-10-2006, 11:34 PM | #1 | ||
Tuned @ Pitlane Frankston
Guys,
Just came accross this on ebay. AU Engines that come with the alternator AND modified sump to fit any EA-EL. They have alloy welded the sump by the looks of it, which is pretty expensive unless you know someone who does it. Quite a good price too. Here's the link: http://cgi.ebay.com.au/Modified-AU-4...QQcmdZViewItem Cheers.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
20-10-2006, 11:37 PM | #2 | ||
Not bad.... That won't suit the 3belt setup though ;)
20-10-2006, 11:39 PM | #3 | |||
Lucky I just converted to Single belt
20-10-2006, 11:39 PM | #4 | ||
Last warning
mmm.. nice
perfect for EF/EL owners! wonder what freight would be worth though.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
20-10-2006, 11:40 PM | #5 | |||
Freight wouldnt be huge.. definetely under a $100 id say |
20-10-2006, 11:40 PM | #6 | |||
20-10-2006, 11:51 PM | #7 | ||
Isnt the whole point of doing the swap to get the single belt and bbm really so it seems a little pointless to me.
20-10-2006, 11:52 PM | #8 | ||
Last warning
not really... AU engines will generally have low km's, i know if i was changing the main reason would be for the lower KM's on the engine.
the serpentine belt and BBM would simply be bonus
20-10-2006, 11:54 PM | #9 | |||
The point of the conversion is to get a MUCH more refined, stronger, more powerful long motor into your E-series. I've got a single belt on my ED engine, and BBM isn't worth the effort. An AU engine is SUCH an improvement over our leaky, crappy E-Series engines.
20-10-2006, 11:54 PM | #10 | ||
AU engines also go a lot better and rev a lot smoother. Even with 3belt setup and EA-D manifold AND they dont leak oil!
20-10-2006, 11:57 PM | #11 | |||
It's amazing that Ford didn't refine the 4 litre before the AU. They had 8 years to do something about them. Took way too long.
21-10-2006, 12:03 AM | #12 | |||
21-10-2006, 12:04 AM | #13 | ||
If i was doing it again id definetely go the serpentine setup.. so much easier just a bit more expensive.
21-10-2006, 03:53 AM | #14 | ||
Once shy... twice bitten
I still don't understand what's wrong with just grinding the ribs back on the front of the sump to make it fit. That's what I done to mine and it hasn't even come close to hitting anything.
$400 for an 80,000km motor that seems to be light years ahead of what I had previously, is more than a bargain
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. |
21-10-2006, 06:19 AM | #15 | |||
Last warning
21-10-2006, 10:35 AM | #16 | |||
Ea Falcon S
so for it to fit into a EA all you have to do is grind the fins?????
or do you have to modify the sump (weld/Cut) aswell.....??....
Jarv Smith 88' Ea Falcon S 3.9MPFI 5 speed Manual Motivator Headers with 2.1/2" RedBack system XR x GT Hybrid Body 15" 'Snowflakes' 90' GL Interior Custom Black Vinyl Roof Custom Console Lid 9" LCD + PS2 Boss CD/MP3 head unit 50x4w Quote:
21-10-2006, 10:59 AM | #17 | ||
So what the KW this thing pulls out ?
21-10-2006, 12:15 PM | #18 | ||
All I done was grind the ribs back on the front of the sump and tapped the bar foward just slightly for safe measure.
KW, I'm unsure of yet it will get dyno'd in December at the Geelong Dyno Day. It pulls waaaay harder, revs smoother, and the BBM isn't connected yet. I can't fault it, and I can beat things I couldn't keep up with previously. That give you a fair indication?
21-10-2006, 12:23 PM | #19 | ||
AU motors are sweet. I drove the GF's AU last night and it feels so much smoother and has more torque at low revs. Not quite as fast as mine but nicer to drive.
Auto is so much better than manual! I reckon a BA motor would be better still though :
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
21-10-2006, 12:35 PM | #20 | ||
ORSM FORD CRUSIERS
the au engine are soooo much better !!!
$1200 is a bit rich though!! i payed 550 with all accesorys and 60,000 then all i did was grind the ribs off the front of the sump and she went in no problems!!! ba motor would be sweet as but $$$ conversion modifying ...
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
21-10-2006, 04:35 PM | #21 | |||
AULTD
21-10-2006, 05:02 PM | #22 | ||
Ok, It seems alot of people don't know the difference between an EA-ED k-frame, and an EF-EL k-frame.
The EA-ED k-frame has a the bar type setup that ned is talking about. The only necessary measure is to grind the front fins from the sump, and push the bar slightly forward so that there is around 3-5cm's clearance. EA-ED is easy, but more expensive, as the single belt system is preferred over converting the AU engine to multi belt. The EF-EL has a completely different k-frame. It's alot thicker, and only allows a small gap for the sump to poke down into. The AU sump fouls the k-frame heavily, and the only way to get the AU engine to fit, is to either; a) Remove the sump and cut/weld it to fit (as the guys in the ebay advertisement have done) b) Modify/weld the k-frame to allow for the extra size of the AU sump. Both of those options are quite expensive. Alloy welding is a specialty, and not as easy as steel. And the other option, I would NEVER cut the k-frame on a car, simply for structural integrity. If someone who had modified the k-frame improperly, without an engineers assistance, got into an accident, the frame could bend alot easier, and make the car unsafe. These engines are pricey, but a god send for EF-EL owners. EA-ED owners can get a cheaper, un-modified AU engine, but will have to spend more money on single belt system. Hope this clears things up.
21-10-2006, 05:07 PM | #23 | ||
Or they can harden the **** up and get the grinder out to make the 3 belt system fit like Doug did many moons ago.
21-10-2006, 05:10 PM | #24 | |||
21-10-2006, 05:55 PM | #25 | ||
likes falcon's
im sure a full reco el xr motor with au internals is better than a grinded up au one :P
www.carhubsales.com.au |
22-10-2006, 10:05 AM | #26 | |||
Location: Under the bonnet, trying to keep as clean as above!
cleared a few things up on how to fit it, yet i still don't know why you should. why are they a better motor? whats different between the EA to AU? |
22-10-2006, 01:47 PM | #27 | |||
Plus, as has been said alot in this thread, AU engines are smoother, more refined, they don't leak, they have less headgasket troubles, they use a 110amp alternator, the bottom end internals are stronger, etc. All around, they are a better engine.
22-10-2006, 07:25 PM | #28 | ||
Main changes are Better head, longer rods (therefore higher piston pin height), crank better balanced, cross bolted main caps, better valve train geometry.
22-10-2006, 08:17 PM | #29 | |||
so the main caps are 2 bolt, but go in on an angle? how is the head better? thanks pete j |
22-10-2006, 08:24 PM | #30 | ||
Better flow (unless you have an EF/L XR head) with smaller ports = better air velocity, smaller valve stems, supposedly has better coolant passages too for more even cooling.
The mains have standard Bolts going straight in but then also have bolts going in at 90deg to the other bolts. |
