Old 08-11-2006, 11:38 PM   #1
S3SR
S3SR's Avatar
Default power steering drinking fluid
theres a little patch where it looks like power steering fluid on my garage floor even smells like it. anyways theres a bit on the spill cover/belt cover thingy i got, when hot (i mean hot damn tville) the level is like halfway between the hot and cold level, top it up...fine next few days the pump will start whirring and i check levels and its done to the exact same level...
checked the hoses behind and tighten/adjusted (looked like it was leaking from there) went for a bit of a drive tonight, checked levels again and its done there again but it doesnt seem to be coming from the pump now....where else might it be leaking from?
but it always goes to the same level (still enough to use it)
anyways any help appreciated
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 11:57 PM   #2
GK
Walking with God
GK's Avatar
Can't tell without looking at it of course, but I bet the little nut that has the seals inside is gone. It's a dodgy design and often needs replacing, just had one replaced on my SR a few weeks back.
The nut is worth about $30 bucks from Ford, and you cut the old one off and slip the new one on. I didn't do this myself though mind you, so talk a mechanic mate that I hope you have.
If this is the bit leaking, you'll most likely end up with PS Fluid on your alternator.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 09-11-2006, 12:42 AM   #3
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
GK
Spot on- the pressure pipe going into the reservoir I would think.
Haven't done one on a six, but mine went and I had to replace the whole thing ($130 from Repco). You can have the fittting welded on but I reckon it would be easier and ultimately cheaper to replace it, but like I say, only done a V8 one, sorry
Also- make sure you top it up with Castrol Syntrans 75W85 oil and not power steering fluid- it will stuff the pump and the rack.
I've said it before but just to recap- post 1996 Falcons use manual transmission oil and not power steering fluid..............
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 12:51 AM   #4
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
Lightbulb
Is it a matter of draining the normal power steering fluid (as this is in the wifes au6), and replacing with the Castrol one? I have a new pressure hose I want to replace to.
Went to an oil place the other day to get some fluid to suit the xr8 but couldn't find any : Thanks James for the correct brand of oil.
Mick
Old 09-11-2006, 01:14 AM   #5
jimt3te50
jimt3te50's Avatar
Mick
The oil is surprisingly hard to get to be honest Mick! All the auto shops just stock 1 or 2 types of power steering fluid..........
It's not a big job to change it Mick........ (the pressure line on a V8 is a PITA though)
2013 Audi SQ5
Old 09-11-2006, 01:24 AM   #6
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
Thanks mate, where did you get yours?, probably have to go to a Castrol distributor is guess or would Ford have it?
Old 09-11-2006, 01:33 AM   #7
jimt3te50
jimt3te50's Avatar
Just order it from Repco the day before you want it and they'll get it in- it's not rare, just that I've never seen it on the shelf..........
Who would think you would need to run Manual Tranmission Oil in your P/S system?
2013 Audi SQ5
Old 09-11-2006, 11:15 AM   #8
S3SR
S3SR's Avatar
not me.
i just bought some valvoline power steering fluid (one with the red au xr on the cover)
thanks GK ill check that hose and the nut, power steering fluid on the alternator means disastor soon doesnt it.... should i just replace that as well?
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 09-11-2006, 08:25 PM   #9
GK
Walking with God
GK's Avatar
Originally Posted by FALCONSR
not me.
If the battery light on the dash doesn't come on, I wouldn't be replacing the alternator!
I have used that same fluid also, it meets the Ford spec so should be fine!
Cheers,
GK
Now gone!
On LPG
Old 10-11-2006, 10:30 AM   #10
all4fordau
Cheers,
GK
Those hoses from the power steering pump are very dodgey. Mine leaked at the nut union piece and dripped into the alternator. I replaced the hose with a unit from Repco $80, and the alternator went fine for a couple more weeks then threw in the towel. Reco alternator was $220 fitted but dont do it straight away unless the battery light does come on.
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 10:38 AM   #11
BlackLS
Power steering pressure switch/sensor. $10 fix.
