Old 16-11-2006, 08:03 PM   #1
GK
Walking with God
GK's Avatar
Default Water Leak
Hi guys,
Been getting water in the boot, not the boot itself, but from the inside of the bootlid, emptying as I raise the bootlid high.
As mentioned a few times, I suspect it's the spoiler bolt holes. But what is the best remedy for fixing the leak.
In the past, JC has recommended rubber grommets, but for the stop light wiring if memory serves me correct.
Someone else has recommended getting rubber and remaking the oval shaped gasket?
Someone else said silastic.
Which of these ideas works the best? As we've been getting heaps of rain lately, I suppose others have been getting this issue coming up again?
Also, will pulling the rubber grommets from the bottom of the boot lid help drain the water in the future? Should I put them back in, as they are rubber stops for the boot lid aren't they?
As always, the discussion and help is most appreciated.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 16-11-2006, 08:21 PM   #2
poolkeeper
Its Resonating!
poolkeeper's Avatar
Like to help, but Ive got a ute, lol :
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 10:57 PM   #3
Syncro
I get the same problem but I have no spoiler, have to look into it further
Syncro is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 10:58 PM   #4
JC
JC's Avatar
GK - have a look where the holes for the boot spoiler go - they are actually on the outside of the rubber seal that seal the boot/bootlid, so it's not them that is causing the leak, and they also go through the top and bottom art of the boot panels which is effectively one piece of metal - ie there is no way for water to enter the bootlid from these holes as the holes don't actually go into the bootlid cavity.
It is definitely the rubber grommet for the electrical wiring - the only cure is a new grommet, or heaps of silastic around where the cable goes into the grommet - the more you coat that hole, the better, as it is the ONLY possible source of water getting into the bootlid. To do this you need to take the spoiler off, which may rip the rubber stuck to the bottom of it, but since this doesn't seal anything, apart from the electrical wiring hole, and you will be silasticing that anyway, there should be no issues caused by the tearting of the rubber bit.
Ford Performance Club ACT
Old 16-11-2006, 10:59 PM   #5
JC
JC's Avatar
Wow, that makes a mockery of my post above. The only other source for water to get in the actual bootlid (and not the boot - not until you open the boot) is the numberplate holes and/or the trim above the numberplate.
Old 17-11-2006, 04:46 AM   #6
GK
Walking with God
GK's Avatar
Thanks JC for that most useful info.
I knew the only other possibility for water in that part of the boot lid was the number plate. I was pretty sure it wasn't that one though, although to check would certainly be easy enough.
It was a 7/8ths grommet wasn't it? That'll test your memory! LOL!
Cheers,
GK
Now gone!
On LPG
Old 17-11-2006, 03:36 PM   #7
GK
Walking with God
GK's Avatar
Ok, so I checked the number plate and wouldn't you know it, the self tappers had gone all the way through the black plasticy self tapping grommet thingy!
How's that for correct teriminology? :
In any case, I took them out, shortened them, reinserted them and popped a blob of All Clear on each black plasticy self tapping grommet thingy!
I'll see how that goes.
Cheers,
GK
Now gone!
On LPG
Old 17-11-2006, 04:12 PM   #8
bodes-sh
just out of interest, how much water was coming out of the lid when you opened it? although it would seem you have found the cause, i would think that there would be a fair bit if it was leaking from the spoiler
Old 17-11-2006, 04:18 PM   #9
GK
Walking with God
GK's Avatar
I've had the car for almost a year now, and it's the first time I've noticed the water issue. The rain the past few days has probably been the heaviest for the longest.
A fair amount came out, not dribbles or anything.
GK
Now gone!
On LPG
Old 17-11-2006, 04:22 PM   #10
bodes-sh
fair enough...well i hope it all goes well, if that doesn't fix it, maybe try having a look at the bolts that hold the boot garnish on, the piece where the number plate lights are that is...i'm sure you probably know what it is, but just to be certain...anyway, it bolts through the boot lid near where the number plate screws go in
Old 17-11-2006, 04:50 PM   #11
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
yeah - i've had this issue too - havent looked into it though cause its rained less the 5 times in canberra in the whole year (well maybe a few more then 5)... no spoiler on mine either..
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 04:55 PM   #12
GK
Walking with God
GK's Avatar
That was something else I noticed as a possibility today! Not likely though, but I did unbolt one side of the spoiler to have a peek. Rubber looked ok, not perished or anything. Gave bolts on both sides of the spoiler a bit of a tweak though, to be on the safe side.
I'll see how that one goes! If there's still water, I'll have a crack at JC's grommet! LOL!
GK
Now gone!
On LPG
Old 13-12-2006, 03:19 AM   #13
Syncro
It's like a handfull or two of water that sit up in the top of the right hand side of the boot, a lot higher than the number plate or boot garnish in mine. I am thinking it may be getting through the gromet for boot wiring in the corner of the boot
