Old 21-11-2006, 12:03 AM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default EA 88 radiator problems
hi, i have a series 1 EA that has the radiator that is to small, so the car ran a little hot today. any advise on what can be done?
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2006, 12:10 AM   #2
fmc351
let it burn
Why is the radiator too small? I thought there was only one for EA. Id look at the thermostat and make sure the radiators flowing properly and doesnt have any blocked cores, collapsed hoses etc. Make sure the cap is good, headgasket etc.
Water pump might not be pumping properly, have you checked the belts etc?
Advice, if it is too small get a radiator to suit before summer fully kicks in. Otherwise go to a radiator specialist and get them to leak test the system and check for a blown headgasket. Theyve got a simple test for it. they should be able to advise if the pump isnt pumping fully too.
Old 21-11-2006, 12:53 AM   #3
needaXYGT
AU II XR8
needaXYGT's Avatar
ok, it could be blocked somewhere. i think they did have problems with the first lot of radiators made for the EA's?
Old 21-11-2006, 01:32 AM   #4
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
or the issue is easyer then that, its an EA, time for twin thermoes
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2006, 08:11 AM   #5
EA2BA
PM me if you want
EA2BA's Avatar
well poor maintenance its old by now and a clutch fan, cooling problems are bound to happen, you probably are missing the bottom plastic plate as well.
try thermos first, failing that get a new radiator, on ebay though some reasonable deals on radiator/thermo fan combos can be had.
Old 21-11-2006, 11:26 AM   #6
Bill_R
Bill_R's Avatar
apprently there were issues with sand from the casting left in the system which settled in the radiator. Flush it out or get it flushed. replace it if necessary.
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2006, 01:26 PM   #7
needaXYGT
AU II XR8
needaXYGT's Avatar
ok, thanks for the advice people.
