Old 22-11-2006, 10:29 PM   #1
STK-XR8
STK-XR8's Avatar
Default help- ef drivers electric window
just brought a ef xr8 ,come home today went to put window up and bang window came back down ,took door trim off and cable is still intack but the spring has broken, how the f#*k does the cable come off so i can get a new one tommorrow.
any help pleaseeeeee.
ta den
STK-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 10:32 PM   #2
SlikedTurb
you can't take the cable off, you need to buy a whole new regulator.
i had the cable go on 3 different windows in my ED Fairmont. they're not cheap either.
SlikedTurb is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 10:41 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
correct buy a new reg, or try a wrecker one, when you get it, you will see how to replace it.
Old 22-11-2006, 10:45 PM   #4
SlikedTurb
they're quite easy to fit. they have some seriously big Rivits holding them in. you'll have to drill them out. don't worry if you cant get rivits big enough to replace them (or a rivit gun for that matter) just use some short M6 allen head screws with a spring washer>
did the trick on my 3 windows!
Old 22-11-2006, 11:52 PM   #5
STK-XR8
STK-XR8's Avatar
dam it i thought i would just replace the cable and all is done...
ohhh well do it once and remember for the next time,
thanks guys for your responce's
ta den...
Old 22-11-2006, 11:58 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
you can replace the cable.
pull the regulator apart and make sure whats broken has broken, if you can get the cable off then you're laughing.
i thought my cable had broken but it ended up being the plasic clip that holds it to the window bracket, repaired and was back on my way.
pull apart completely before buying a new one
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 23-11-2006, 03:48 AM   #7
Jayden
Graphic Artist
Jayden's Avatar
These things always break, glad I got manual windows really as its hardly any effort. and manual is better in races :P
For crimes against aesthetics in automotive culture, I sentence you to a life of commodore.
Jayden is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2006, 02:24 PM   #8
SlikedTurb
no worries MK11, good luck with it!
