Hey guys,
Just wanting to get an idea - how many people warm up the car in the morning/first start of the day? I've been told its a good habit to get into but rarely bother, as I'm always in a rush in the mornings. ![]() Good on yas! Pully
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
about 5 mins for me, depending on if its hot or cold. If its a hot day 5 mins max, a cold day 7-8 mins.
Get in the ring!!!
Don't think you really need to with modern cars, they are built to much finer tolerances than older engines. I don't push my car too hard until the guage starts to move, but I don't ever sit there and warm it up either.
FG MKII XR6T - Tuned by Pit Lane |
Shoot.
Pretty sure you shouldn't be warming up a modern car before driving off for some reason (from what I've heard, don't know exactly why). It's best to drive them straight away and drive the car gently until the temperature is in the normal position.
20V Turbo |
LPG > You
Every car I ever own will be warmed up before driven anywhere.
yeah i drive strait away, As long as she starts.
Rider on the storm
EA2 Falcon: Yea, a little. About a minute or two so it doesn't cough out when idling.
'85 AS Telstar: For at least two or three minutes. It jumps and sputters when it's cold, even with the choke out. I think in modern cars it's redundant, and by sitting there idling you're consuming fuel and not warming anything else up (transmission, clutch, tyres, brakes, etc). |
#8 | ||||
own the road
lol. same here.
T3 TE50 #146 Quote:
#9 | |||
RAGE Engineering
Most people think the "warm up" procedure is getting building heat into the engine, whereas what it really means is letting the oil circulate and get up to pressure before driving. "Warming up" comes from the days of the carburettor - a stone cold engine does need a bit of temperature to get it running right. Hence the choke, which is automatic these days.
If it doesn't fit, use a BIGGER hammer Last edited by FFOracing; 13-04-2005 at 06:56 PM. |
#10 | |||
Detroit Locker Equiped TM
XR6, usually give it a couple of minutes in the morning to get some temperature into the engine and get the heater working. I don't really like driving straight away on a stone cold engine.
As for the GT, ask anyone who was at Heathcote and stayed at Bendigo. ![]()
Apollo Blue 1974 XB Falcon GT, 557 HP Blue Pearl 2004 BA FPV GT, 290 kW Quote:
http://www.facebook.com/FalconGTClubGeelong |
In my shitty EA I've usually half-way released the clutch before it even kicks into life! I have to warm up my XA or it just kicks and coughs and basically acts like a ****er.
#12 | |||
![]() Join Date: Dec 2004
Nope, I just get in and go. I do take it pretty easy for the first 10-15 mins though
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
I dont warm mine up. Just baby it along untill it gets to a good enough temp.
#14 | ||
ED Fairmont 4.0L
I do with the Fairmont coz the automatically adjusting idle-plunger is missing (plug's still there) and if I don't she has a tenedency to stall when changing from reverse (to get outta driveway) into drive. Tend to warm her up for about a 15-30 secs (depending on how cold it is) at about 1500rpm.
B'jabbers! |
#15 | ||
i open the door start her up... get in do up me seat belt.. stick the face on the headunit.. select a good song if a good 1 isnt on.. throw on my sunnys and away i go
so it gives it a good minuite or 2 or 3 to warm up and just take it pretty easy till the guage moves a fair bit |
#16 | |||
I let the oil pressure get up and then drive slowly until it reaches temp. |
#17 | ||||
#18 | |||
#19 | |||
_Oo===oO_
I usually do a few stretches. Oh, you meant the car....
#20 | ||||
#21 | ||
I just usually start mine up in the morning, let it idle until full oil pressure is up and take it real easy till the temp guage is in its normal operating range.
#22 | ||
Former E-Series Member
In my experience cars drive like crap if they are too cold, and if they are carby they don't drive at all unless warmed up reasonably. All the propoganda by the oil companies about most engine wear occuring in the first 15 minutes has made me paranoid and I do warm up cars up.
#23 | ||
What a good thread.
I definately warm up my XA fully - for easily 15mins - usually up to full temp. Probably overkill I know. |
#24 | ||
The one and only
You do not want your car to idle up to temp. The longest time needed at idle is about 10-15 seconds, this is how long it taks to get oil pressure.
Then drive car gently until engine temp is met. Then drive as hard as you want. This is that safest way and will lenthen the life of your motor. If you idle up to engine temp then you are doing more bad than good.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#25 | |||
FORMERLY TX3DUDE
i tag the limitier when starting, slam it into drive and do a 400 meter long skid to warm it up....works everytime...just joking. fairmont gets thirty seconds of idle. laser turbo gets a full 10 minutes while i do my pre flight checks.
#26 | |||
LPG > You
My dad's done that on every car we've owned (two Ford Econovan Maxi's, one did 404,000km, the other has 500,000 on it now and still going), pretty much all the cabs he drives/has driven (right now its an AU1 with 850,000km on it) etc etc. And they all tend to live a long and healthy life.. so it leads me to believe that it actually is a good idea. |
#27 | |||
As he said ^^^ word for word. Plus wait for the roller door to raise up. |
#28 | |||
Cars these days dont need to be warmed up... unless like smciner1's they dont idle :P
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
#29 | |||
RIP...
Idling for more than 20 seconds is just a waste of fuel. Driving off immediately is the best way, if your vehicle is capable of it. That is, if it doesn't have a very good enrichment circuit for cold running. All EFI vehicle made in the last 10-15 years shouldn't have any problem with that. The other problem with allowing a vehicle to warm up idling is that all the other components aren't warming up with the engine. There is little point allowing the engine to warm up if the gearbox, diff, brakes, and tyres are all cold. Moving off straight away is the best method of warming up any modern day vehicle. Of course not allowing revs to go over (say) 3000rpm is a good idea until the engine is at operating temp. Allowing engines to warm up is a thing from the dark ages, when we had single grade oils and vehicles simply wouldn't run without warming up. Rick.
. Oval Everywhere... Last edited by Sox; 14-04-2005 at 02:08 PM. |
#30 | |||
Apparently us odd ones who drive AU1's and not those "fancy" AU3's actually have working oil pressure guages so we can actually see the pressure guage go up and reach full pressure. ![]()
