Old 01-12-2006, 03:07 PM   #1
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Default Fitting cruise control (Auto)
Hey all.... I'm trying to help a mate with his heavy foot problem and our first line of business is fitting cruise control to his AU1 forte....
What parts do we need?
Steering wheel Buttons
Indicator stalk
Wiring
Cuise control motor...
anything else? Does anything need to be fitted to the brake pedal or should it all be fine?
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2006, 03:17 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
Brake Pressure switch for the master cylinder.
while not 100% needed (you can jump the wires)
its a backup for if the brake light switch fails.
apart from that i think you've got everything listed.
i put this onto my mum's AU wagon a while ago and i can't recall anything else you'd need.
make sure you get the whole indicator stork assembly (both sides), its easier :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 23-11-2009, 02:57 PM   #3
Hords
Treasure your balls?
Hords's Avatar
I don't think you have a choice. It's a complete assembly as far as I'm aware.
I'm researching as I broke the indicator stalk off last Fri. Try using the indicator switch when it's snapped off near the base - FPITA!
Bayford want $245 (trade). See what FTG come back with.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 03:07 PM   #4
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
http://www.fordforums.com.au/showthread.php?t=11246180
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 05:07 PM   #5
frd906
i broke my cruise buttons off, off to wreckers soon to grab another 3 or 4 just in case, atm ive taped mine up so it dosent look so bad, but i rarely use it.
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
