05-12-2006, 09:52 PM | #1 | ||
Hey guys. I've got 10 grand to buy and tweak an ED 5L.
I've driven a couple of autos...about 5 grands worth... and they seem a bit gutless in standard trim. How should I spend the remaining $5000 to liven things up??? I spoke to Jim Mock, he recommends: flash tune for engine and auto, progressive stall converter, new exhaust and a 345 diff. What do you guys reckon....will this make a worthwhile difference ?? Your opinions will be appreciated. Thanks |
05-12-2006, 09:54 PM | #2 | ||
MADED.6
i would say put some gt40p heads on a bit of a cam the au intake manifold and full exhaust cold air intake and some form of chip that should get it going a bit better. and yes they are pretty gutless in stock trim but can get going pretty good.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
05-12-2006, 09:59 PM | #3 | ||
V8 Ute V8 Boat
use the 10g to put a deposit down on a house in a good suburb
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
05-12-2006, 10:01 PM | #4 | ||
rofl copter
5 grand for a ed 5 ltr? fairly big price, buy privatly and u should be able to get one for 3.4 -4 and do what 94edghia said. or u could slap a blower on it or TT if you know the right people
GQ patrol.
.... thats all |
05-12-2006, 10:08 PM | #5 | |||
own the road
Yeah 94EDghia is on the right track.
Explorer Manifold and Full Exhaust would be my first mods. Also check out the Windsor forum Here - Plenty of useful info in there
T3 TE50 #146 Quote:
05-12-2006, 10:17 PM | #6 | |||
Shoot.
20V Turbo |
05-12-2006, 10:25 PM | #7 | ||
if you really have that sort of readily avail cash go twin turbo then get a big loan to get it legal (it only cost me $2,500.00 10yrs ago)
i have been there in the past as much as i would like to do it again i dont think i could afford the engineers cert these days and i earn a crap load more now than i did then jason
05-12-2006, 10:31 PM | #8 | ||
You win again, gravity!!!
Forget Jim Mock... he has seen that you have money to spend, and is just wainting to take it from you... Flash tune on a stock engine?? no point at all...
What has been said here is a good start, cover the basics first... Full exhaust Cold air intake Half decent ignition Crane 2030 Cam (A popular street cam) AU GT40P heads (Ported if funds allow) AU Explorer intake manifold (Again, match ported if funds allow) That basic combo should be good for minimum 300 - 330hp at the flywheel. After you have an engine like this, only then will a flash tune be worth the money. This is what I am planning for my Fairlane, and the dyno2000 software predicts the following:- Basically, what I said above should give you this result, plenty of bottom end torque, with a good power curve. Exactly whats required for a streetable engine. Hope that helps!
1966 Fairlane 500 XL
06-12-2006, 12:13 AM | #9 | ||
Screw that
Buy an EA for next to nothing and the rest on a turbed 6 will blow any worked 8 away specally if your going to spend 9 odd g on the engine;) |
06-12-2006, 12:52 AM | #10 | ||
bettering 13.7
depends on what the car you have has allready done to it.
basics first full exhaust - extractors, cats, and a good free flowing mandrel bent system EL thermo fans underdrive pulleys 70mm MAF 65mm T/B the above list will give you a good start, and leave plenty of cash behind to give her a good service. new plugs and leads tranny service oil and filter full cooling system flush fuel filter uni joints diff oil change new brake rotors and performance pads decent tyres the above is only a suggestion but when you first get the car go through it top to bottom and give her a really good service - safety and reliabilty are the first things that should be looked at on a new/secondhand car, then start chsing some HP
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer FPV/Tickford Club of W.A Performance is Electronic BPT Motorsport |
06-12-2006, 12:54 AM | #11 | ||
my god, if your got that much to spend you will have one tuff v8. You could always buy one already modded, it will save you having to do all the work. Check this out for 10 grand
EB XR8, Stroked Note- how he says you can drive this car on p'plates..........lmao Anyway, you could do that or buy a ed sprint or a a stock v8 and do that up the way you want it. Eg. supercharger, stroker, turbo or N/A. With 5 grand to spend its possible to get some serious power out of the car. The americans have alot of info about windsors and modification, do a google on the windsors and have a look. For 5g's you would want to do heads (AFR or trickflow, even GT40 heads), a nice cam (to work with the heads, for maximum power), inlet manifold (theres heaps on the market, its just a matter of what you want), exhaust system and a tune........and possibly a stroker kit (but thats gona cost you more :1syellow1 ). You could even buy a T3 engine and drop it into an eb? theres heaps of options!!!. |
06-12-2006, 01:06 AM | #12 | ||
Just a spectator
Or you could check out the Ford Motorsport catalouge or buy a couple of American Mustang mags,or google it.They have street 5L's running some good times.Look up Trickflow,Elobrock and the like.They have complete packages which include heads,manifolds camshafts and valve trian.Can be dearer if brought separately.Or I like the idea of buying a cheap car as suggested ,there was an ED fairmount in the 'cars for sale section' nothing wrong with it for $1000 now its being wrecked as we speak then Turbo it still have some money left over and wax most things out there.
Cya Lukey. |
06-12-2006, 01:07 AM | #13 | |||||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
mainly depends how much boost the 6 is running, and just how 'worked' the 8 is.
2024 Audi RS 3 Sedan - Mythos Black 2024 BMW M240i - Zandvoort Blue 2023 Skoda Superb Sportline Sedan - Steel Grey |
06-12-2006, 01:16 AM | #14 | ||
Just a spectator
Correction the Fairmount I was talking about is in the spare parts section and it looks just about gone.There was I noticted an EA for $1500 and a ED for $4500 with all the trick stuff.
Cya Lukey. |
06-12-2006, 01:50 AM | #15 | |||
06-12-2006, 07:44 AM | #16 | ||
The one and only
From what I have heard, don't go to rhe 'Ford performance enhancers' as they will rip you.
I agree with eb2flyz but I would put a mild cam in too, similar to what Fairlane Ghia suggests.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
06-12-2006, 10:24 AM | #17 | ||
The 'Stihl' Man
Why not get a capa supercharger kit, then just do the exhaust?
Would a charger on a stock engine make more power than an engine with a mild cam and gt40's?
06-12-2006, 11:11 AM | #18 | |||
I had a pretty worked EB 5L once, more trouble than it's worth and it drained my pockets so much I had to convert it to gas... then you lose all the top-end power. Sundeep |
06-12-2006, 11:40 AM | #19 | ||||
Official AFF conservative
GDT - just supercharge the thing and be done with it. Quote:
Power numbers werent huge (170rwkw) but the torque was ridiculous. My graphs are kicking around here somewhere.... To directly answer your question, im not sure. My car's g-tech time was 14 seconds flat. What does a set of gt40s and a bump stick get you? Also depends on what the authorities in your area are like... blower will raise a few more questions regarding roadworthiness than heads/cam will....
A cup half empty... but full of euphoria. |
06-12-2006, 01:49 PM | #20 | |||
The car seems totally legal to me, aftermarket ECU is probably only item you 'may' have problems with insurance/EPA if it comes to that. Police/Vicroads/Insurance Companies all go by stock power and weight figures so he's fine even it was 300rwkw. For police to challenge the power/weight of the car they would have to have it put on an engine dyno etc to have any chance of their evidence holding up in court which of course is a huge waste of there already restricted resources, thus would never happen. So no problems with stroked e-series in Vic |
06-12-2006, 02:15 PM | #21 | |||
06-12-2006, 02:28 PM | #22 | ||
bettering 13.7
I personally wouldn't go all out with the mods first, do all the basic mods which are pretty insurance friendly. make sure the car is in good/safe running order, remember it's age they are steting to get on a bit now and will require things to start getting replaced ie....
brakes - service/replace? cooling system - service/replace? suspension bushes and shocks - inspect/replace? tranny inspection - sevice/rebuild? diff - service/rebuild? going fast doesn't mean anything if the car isn't safe or roadworthy - just means that it will become an accident waiting to happen. the list I did above could chew out 5K easily enough depending on the condition of the car. after you are satisfied with the above work out how much you have to left to spend then look into doing the basics first full exhaust sytem - depending on what the car in ???? already has EL thermo fans - getting rid of the heavy viscous clutch fan underdrive pulleys - a proper 3 pulley set, this allows you to keep the std size belt K&N filter with a CAI 70mm MAF - the std 58mm is one of the main restrictions to the intake system 65mm T/B - the next restriction t the intake system after those you start talking $$$$$$ depending on how much you are willing to do yourself will determine the total price
06-12-2006, 02:48 PM | #23 | ||
Check this one out:
Forum members car, if it was a 6 I would have already bought it! price has been dropped to 9k with massive stereo or 7k without...its already got a 9 inch and rebuilt auto (saving you somewhere around 6k already, because if you want a good motor your going to need a good box and diff to match) motor is near stock and just waiting for forced induction or a new top end... Clicky Clicky And I forgot to say...it looks The Business. |
06-12-2006, 02:59 PM | #24 | |||
If you could get those figures with a mild cam & GT40's, I wouldn't have bought a charged car. Boost is the best bang for buck. It has been tried and tested. But it does require a bit of cash to start off with, and would be pushing your budget for this project.
2002 Suzuki GSXR1000: Yoshi pipe and cosmetic enhancements only. 10.7 1/4 mile 1995 EF XR8: Pacers, 3" all the way, stereo & Vortech V2=297rwhp, 13.5 @ 105mph 1/4 mile Its not a TICKWUMP, its the TICKWUMP |
06-12-2006, 04:07 PM | #25 | ||
The 'Stihl' Man
I thought the CAPA kit was around the $5k mark?
You could easily find an EB/ED 5L for under that. Would be best to pick up an EB XR8 so you get the diff aswell.
07-12-2006, 11:15 AM | #26 | |||
ED XR8 + extractors + exhaust + charger = ~$12-14k roughly by my calculations. A bit over the budget.
07-12-2006, 07:21 PM | #27 | ||
GMHKLA number plates
put a charger on it n slap some AFR Alloy heads n manifold fk that cast iron sht
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
07-12-2006, 07:27 PM | #28 | |||
I weighed a 4 litre head a little later, and the head including valves, springs, camshaft and rocker gear was only 23kg! |
07-12-2006, 08:32 PM | #29 | ||
Just a spectator
There's nothing like removing/fitting a set of cast Iron heads to a V8 in the car.Not quite enough room to have 2 people without holding your tonuge right.
Cya Lukey. |
23-12-2006, 02:58 PM | #30 | |||
HSV - I just ate one!
i know where i can pick up a rough poly green sprint, also from march 94, manual and factory towbar, new tyres and a brand new michelin on the spare, exterior has a fair few scratches (god bless the owners kids the little c***s), front spoiler is missing courtesy of a wallaby, and the interior is a bit sad, but only 163,000km on the clock for $7-8k |
