Old 11-12-2006, 09:43 PM   #1
infusion
Default Stereo Wiring EF
hey guys im running amp/stereo wiring etc tomoz..
just wondering is there any tips for running the Red cable through the firewall to the rear...
and any tips on getting sterero wiring through the rubber thingy between the door and body on the front doors.
any other tips?
im running an alpine head deck 3 pre outs
10 inch sub
Mb Quart 6 1/2 inch splits in front doors.. ( good place to mount the tweeters? anyone?)
and a alpine v12 which i will run the sub and front splits off...
Oh yeah one other question... the sound deadening material that seems to be in the doors, when i fit my speaker in the hole it pushs the material against the window causing rubbing.. can i just cut out that tiny but covering the back of the speaker or does it protect it if water runs down the inside of the door..
thankyou in advance!!
cheers guys!!
infusion is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2006, 09:53 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
if your cars auto go through where the clutch cable goes
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2006, 10:04 PM   #3
infusion
manual lol :eclipsee_
Old 11-12-2006, 10:21 PM   #4
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
well i drilled mine neer the steering, i ran 4 gage wire i can take a pic tomorrow if you like
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 11-12-2006, 10:39 PM   #5
infusion
so you drilled yours? didnt run it with the existing loom?
Old 11-12-2006, 10:42 PM   #6
OED666
OED666's Avatar
i ran my 4 gauge through a hole in near the brake booster... its slightly hidden away. run your power and amp signal wire on the same side. run your rca's on a separate side.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2006, 10:42 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
not a 4 gage wire
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 11-12-2006, 10:57 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I was just typing that....bugger !
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2006, 11:00 PM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
yer i worked out the hard way they cant go the same side and had to do it all again
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 11-12-2006, 11:01 PM   #10
infusion
yeh thanx for the tip guys ill be running them separate sides..
anyone know about running wire to the doors?
Old 11-12-2006, 11:02 PM   #11
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i didnt go that far for doors i said stock wire was good enough for the front, well it was for me and im not that lazy
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 11-12-2006, 11:44 PM   #12
sphell
sphell's Avatar
use WD40 to get wires through door rubbers easier.
Old 12-12-2006, 09:20 AM   #13
OED666
OED666's Avatar
not a 4 gage wire
what do you mean...
i did put a 4 gauge wire through a pre-drilled hole in my firewall...
Turbo Barra ED 4L
Old 12-12-2006, 11:28 AM   #14
joolz
I ran my power via behind the drivers headlight then inside the drivers guard under the liner then through an existing gromet behind the drivers kick panel next to the accelerator. No cables going through the engine bay and alot neater.
joolz is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 11:28 AM   #15
infusion
im using 4 gauge as well..
sooo far soo good ran rca and speaker cables down the passenger side of the car..
now im about to have a crack at getting the red cable through the firewall.. will let you know how it goes..
Old 12-12-2006, 11:54 AM   #16
OED666
OED666's Avatar
yea, thats another way of doing it...
also make sure your fuse is easily accessible, and closeish to the battery...
Turbo Barra ED 4L
Old 12-12-2006, 12:37 PM   #17
infusion
alot easier than i thought guys... now im up too wiring the splits in the doors...
does anyone know if that moulding behind the speaker that covers the back of it protects it from rain?
because my new splits is causing it to rub against the window.. i was going to cut abit of it out but then i was worried it might protect it from water... any ideas?
Old 12-12-2006, 01:07 PM   #18
OED666
OED666's Avatar
i dont have it on my drivers door, but i will be putting it back soon. ed's have thin plastic stuff, and i am in the process of replacing it with EF insulation.
My drivers speaker is fine without anything covering it, so you could cut only as much as you need off.
Turbo Barra ED 4L
Old 12-12-2006, 04:26 PM   #19
infusion
quick question.. how the hell do u dissconnect the inner arm from the central locking so you can remove the inner door completly?
Old 12-12-2006, 04:30 PM   #20
OED666
OED666's Avatar
you shouldnt have to. you definitely dont want to remove the rod for the door handle. they are a pain in the ****...
from memory this is how i take the insulation off...
door trim off, then speaker out. then peel forward the insulation, and lift up over the snipper button rod. then you should be able to slide the insulation towards the front of the car...
Turbo Barra ED 4L
Old 12-12-2006, 04:56 PM   #21
infusion
i need to dissconnect the rod latch so i can take the trim off.. otherwise i cant take it off
Old 12-12-2006, 06:39 PM   #22
Jet-Star
Grab the rod with some pliars and then twist the door handle by hand in the appropiate direction to remove the rod from the clip. Hard to discribe....But you'll get it.
Jet-Star is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 09:03 PM   #23
OED666
OED666's Avatar
if you could get a pic of that your having trouble with i can help you...
Turbo Barra ED 4L
Old 12-12-2006, 10:39 PM   #24
infusion
its kool guys i got it
thanx for all your help so far.. will be finished hopefully tomoz..
Old 13-12-2006, 03:11 PM   #25
infusion
all finished guys!! :1syellow1 :1syellow1 :1syellow1
just need to find a place in the boot to mount my amp and somthing that will hold my sub box down..
Old 13-12-2006, 03:17 PM   #26
OED666
OED666's Avatar
good stuff... i am also trying to think of somewhere out of the way to it an amp... keep us posted as to where you place it.... try not to put your amp upside down if possible... the heat will stay inside... (just incase you were thinking of mounting it under the rear parcel shelf)
Turbo Barra ED 4L
Old 13-12-2006, 03:28 PM   #27
joolz
Mounted my 2 amps under the parcel shelf but on a custom shelf so as the amps are the right way up and the controls are facing out in the boot. The distribution block is also on there and can be accessed by folding the seats down. The only hassle was the mounting bolt for the centre seat belt. The sub is secured the the carpet with the prickly part of velcro, it can be moved easily but wont slide around.
Old 13-12-2006, 04:22 PM   #28
OED666
OED666's Avatar
i like that... i have thought of doing something similar...
Turbo Barra ED 4L
