12-12-2006, 06:50 PM | #1 | ||
Nat D
hi all, ive done a head in the xr, so im looking into rebuilding it.
however i'm also interested in putting in an AU motor. does anyone ahve any clue how much a mechanic would put a au xr6 hp motor in for? any help towards this subject would be great.
old ride#1: ED XR6 5 speed-gone to new home:( old ride#2:dumped EL fairmont 5l new ride: Winter white AU2 XR8-manual |
12-12-2006, 07:13 PM | #2 | ||
Only a matter of time.
What car do you drive?
"SOUNDS THAT GO BUMP IN THE NIGHT" |
12-12-2006, 07:14 PM | #3 | ||||
Burnin Rubber
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
12-12-2006, 07:15 PM | #4 | |||
Burnin Rubber
Shouldnt cost to much, not sure exactly on price, but you would need a long motor. Bit of grinding involved too.
12-12-2006, 07:17 PM | #5 | ||
Wrong forum mate. Theres an E-Series section just for these questions. You've been here for 18months so you should know better.
12-12-2006, 07:17 PM | #6 | |||
Ask wreckers and even auto electricians if the wiring is different they can do it as mechanics don't always like conversions.
12-12-2006, 08:21 PM | #7 | |||
Nat D
yeah guys its an ed xr6 manual ill go put it in the correct forums i apologise for any huge issues this thread has created, and i hope nobody needs therapy caused from accidentaly putting it in the wrong forum.
12-12-2006, 08:26 PM | #8 | ||
Nat D
its all good, some kind mod has moved it,
so does any e series boys have any ideas at how much it would cost? any mechanics that would know a price they would charge?
12-12-2006, 08:32 PM | #9 | ||
The 'Stihl' Man
Mate do a search, actually I think there is even a sticky in the technical section.
12-12-2006, 08:37 PM | #10 | ||
Nat D
i searched for ages, yeah there are heaps of threads but i couldnt find any actually telling me how mucha mechanic would actually drop the motor in for
12-12-2006, 10:24 PM | #11 | ||
a mechanic would charge heaps and tell you it isn't worth it. Just repair your current head maybe get it cleaned up and a new gasket, wallah good as new. Unless it has a billion KM's on it.
12-12-2006, 10:28 PM | #12 | ||
rofl copter
yeah just do the gasket, but if u really wanna do an au conversion, motor is like 700-900 bucks for a long motor depending where you get it, to fit it you need to grind the fins off on the front of the sump, fit your intake manifold and the bottom 2 bolts on your auto/manual bellhousing wont line up, thats it
GQ patrol.
.... thats all |
13-12-2006, 10:06 AM | #13 | ||
Nat D
thanks for that boys, it seems its gonna cost me a similar amount of money to get an au engine, plus a mate said he might be able to help me put it in.
13-12-2006, 10:29 AM | #14 | ||
Tuned @ Pitlane Frankston
Your mate know anything about retrofitting an AU engine into an ED?
Do you have a serpentine belt system? Will you run an EL ECU + AU BBM manifold, or use the ED intake manifold? It's not as easy as just 'put it in'.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
13-12-2006, 10:49 AM | #15 | ||
Nat D
yes yagz,
it is as easy as 'put it in' for him.lol
13-12-2006, 10:54 AM | #16 | ||
You didn't answer my questions..
Multi belt setup on an AU engine is far from desirable. Good luck though.
13-12-2006, 11:06 AM | #17 | ||
Nat D
yeah i didnt answer them cuz i dont know, but he knows, ive decided il probably just recond my original head anyways, shave it a couple of thou and maybe get a port job done
13-12-2006, 06:03 PM | #18 | ||
rofl copter
its not that hard to do an au motor, but easier to get your motor redone.
GQ patrol.
.... thats all |
13-12-2006, 10:13 PM | #19 | ||
Pulled out the records for my car, which had a rebuild under the previous owner. Labour costs for dropping in the same motor came in at $720 and the rebuild was $2700. This is for an EF XR6. Hope it helps.
14-12-2006, 12:20 AM | #20 | ||
AU engines are easy to fit... walk in the park...
its pretty straight forward. definitley run serpentine setup. get all the accessories included as well. all you manifolds bolt straight up, your dizzy fits. no re-wiring. you will need thermofans if you dont already and its a good excuse to put them in.
Powered by Rollin Motorsport Turbo Barra ED 4L
14-12-2006, 12:48 PM | #21 | |||
ORSM FORD CRUSIERS
mine only cost me $550 with all accesorys!! can't go wrong
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
14-12-2006, 12:52 PM | #22 | ||
Nice looking water pump:P
14-12-2006, 01:17 PM | #23 | |||
ORSM FORD CRUSIERS
14-12-2006, 01:38 PM | #24 | |||
Does it lag engine performance tho coz I heard off my mate's, sister's, brothers, cousin that he had one that's biger then your's on his H3KT1C VL and it laged hard core But it made this fully S1K noise chik's allways used to look at him it was awsome down lygon. |
14-12-2006, 02:01 PM | #25 | |||
ORSM FORD CRUSIERS
14-12-2006, 03:46 PM | #26 | ||
Well someone on the forums may acually beleve in all ur B.S ur posting up!! LOL guys
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
14-12-2006, 04:09 PM | #27 | |||
ORSM FORD CRUSIERS
what BS its all true, the au engines are great and fit so well into the EA EB ED's gring the sump a tad and use the standard engine mounts and sweet as power!!
14-12-2006, 04:13 PM | #28 | |||
