18-12-2006, 07:17 PM | #1 | ||
75th anniversary
would any one know if a trip computer will go in to a series 1 eb gl falcon
18-12-2006, 08:00 PM | #2 | ||
ORSM FORD CRUSIERS
yes but you have to do some wiring.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
18-12-2006, 08:09 PM | #3 | ||
ORSM FORD CRUSIERS
EA-ED Trip Computer Detailed Wiring
Pin 1 Black Battery Ground (-) Supply Can be connected to any ground source (I.E. Battery, Cig Lighter Socket ground, etc. etc. Pin 2 Yellow/Green Instrument Cluster Fuel Level Sender Low/Mid Series Clusters, Pin 2 on the 16 Pin Instrument Cluster Connector (Lower Connector) High Series Clusters - Pin 3, of the 16 Pin Connector (Lower Connector) Pin 3 Yellow/Black Constant Battery Power (+12V) Can be obtained from battery, or Ignition Switch Pin 4 Black/White Trip Computer LCD Dimmer Signal Low/Mid Series Clusters (No LCD Dimming), Connect to Blue/Red wire, Pin 1 on the 12 Pin Instrument Cluster Connector (Upper Connector) High Series Clusters - Pin 7, of the 20 Pin Connector (Black/White Wire) Pin 5 Green/Violet To Fuel Injection PWM Output on EECIV Middle Row on EEC connector, 4th Pin from centre bolt (Outward) - Green/Yellow (For 3.2, 3.9-EFI, 3.9-MPEFI, 4.0-MPEFI, and V8 Models) Pin 6 Black Battery Ground (-) Supply Can be obtained from any Ground source Pin 7 Not Used / Connected Pin 8 White / Black Instrument Cluster Buzzer Output (High Series LCD Clusters Only) Connect to Pin #12 on the Lower Instrument Cluster Connector (16 Pin Connector) - LCD Clusters ONLY! Pin 9 Brown Instrument Cluster Positive Illumination Can be obtained from Park Lamps, Cig Lighter Illumination, or Instrument Cluster, Upper Connector (12 Pin) - Pin#3 (Brown Wire Colour) Pin 10 Not Used / Connected Pin 11 Red/Green Ignition Power (From Ignition Switch) Can be obtained from Instrument Cluster (Red/Green wire), or from the Ignition Switch Pin 12 White Instrument Cluster Speedo Sender Instrument Cluster connector - Pin #29 - White wire colour
18-12-2006, 08:38 PM | #4 | ||
75th anniversary
thanx for that
