Old 19-12-2006, 05:38 PM   #1
pla_inter
Default low washer level light
The low washer level warning light on my ED has recently come on but Ive checked the fluid level and it is actually full. No big deal but it is kinda annoying. Any ideas?
pla_inter is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 06:11 PM   #2
malta123
malta123's Avatar
float switch stuch shake the bttle might free itup
malta123 is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 06:13 PM   #3
Allen
You win again, gravity!!!
Allen's Avatar
I couldn't understand any of that :P
Anyway, my NC did this, and I found that the float, no longer floated... So I did the e-series thing and tied it up with a zip tie, and the light never came on again.
Just be sure to check the water level reguarly if you do this, as if it drops you wont know about it until its too late :P
Or alternativly, get a new sensor.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 06:14 PM   #4
DOC
DOC's Avatar
If your in Vic, it's due to the stage 3 water restrictions coming into play, your reading will be correct on mondays, wednesdays and saturdays. On the other days you are resticted from having or being able to use the water hence the light comes on showing empty and not to use your washers to clean the window.
Failing that yes as above re float the float.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 06:37 PM   #5
malta123
malta123's Avatar
thats exactly what i just said so i cant pell big wheel
