Old 29-12-2006, 02:10 PM   #1
EA18
Default el fairmont trim problems!!!! help needed
hey guys, i am currently taking off my el faimront trims. i have taken off all the screws and the door handle but there seems to be some kind of clip behind it which is stopping me from taking them off.
thankx guys!
EA18 is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 03:02 PM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
just pull the door trim upwards. at the window there is a clip that runs the whole length of the window. so just use a bit of firm force to pull it off. hope this helps.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 03:08 PM   #3
EA18
cool thanks, i will try that and get back to you!
Old 29-12-2006, 03:10 PM   #4
BADan
BADan's Avatar
Don't forget the screws in the arm rest thing. There are two large screws to remove.
BADan is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 03:15 PM   #5
EA18
tried it and im thinking that my el might have a clip on it somewhere on the inside of the trim. do u drive either an ef or el? thanks
Old 29-12-2006, 03:16 PM   #6
EA18
how do you remove those screws?
Old 29-12-2006, 03:28 PM   #7
EA18
done and done. thanks guys!
Old 29-12-2006, 05:33 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Bugger I just read this thread and just took the trims off last night, again, stupid speakers..........
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
