Old 17-02-2007, 10:58 AM   #1
ebfalcon13.5
grey bumperz
ebfalcon13.5's Avatar
Default best place to wire a kill-switch to
hey i know pre EF falcons have poor security and apparently are easy to start without the key.. im thinking of putting a killswitch maybe to the ignition and/or fuel pumps etc.. which would be the best place to wire the switch into? i was going cut/resolder a couple of wires straight from the ecu, should i do that or not?
some suggestions would be appreciated
cheers
ebfalcon13.5 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 10:58 AM   #2
ebfalcon13.5
grey bumperz
BTW car is an EB, not an EF
Old 17-02-2007, 10:58 AM   #3
LUXO_8
windsor user
i reckon one of the best killers is to coil or to fuel pump, or both....
no fuel or spark = no go
Old 17-02-2007, 11:03 AM   #4
ebfalcon13.5
grey bumperz
ok sweet well where would i get access to the wires should i run set of wires through the firewall for the coil? or is there alternate route cheers
Old 17-02-2007, 02:05 PM   #5
LTDHO
The one and only
LTDHO's Avatar
You can disrupt the power to the pump after the relay by fitting another relay.
Same deal can be done for the coil or starter.
Try and do it after ECU to make it harder to steal
Tuned by CVE Performance
Old 18-02-2007, 12:11 AM   #6
ebfalcon13.5
grey bumperz
thanks LTDHO, but i dont entirely know what you mean by do it after the ECU... should i run the wires straight from the left hand side kick panel where the ECU is to the switch(if so which wire from the ecu would it be?) or should run a wire from where the fuel pump is and also is the second relay needed if i am using pretty thick 1mm building wire for the switch wire (same as what we use to wire up 240v light circuits with) and a high current switch...i mean i know how to wire up a simple relay circuit but is it really necessary? and for ideas where to put it i was thinking about putting it in the lift up lid in the center console any other suggestions?
EB with sik exhaust and subs and XC falconsik is a banned word?(needs new motor)
Old 18-02-2007, 03:21 PM   #7
gthofan
Gunna girlie-man
gthofan's Avatar
i understand what you want to say. just attach a switch to the positive wire to the fuel pump, and hide the switch somewhere. to interrupt the circuit, hence no power to pump. im not too sure which or where the wire is to the pump though sorry
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 06:19 PM   #8
ebfalcon13.5
grey bumperz
thats cool ill just run two wires from my boot to the switch and try and find which wire the igniton pinout on my ecu is does anyone know where i can find the ecu wiring diagram pinouts for eb's?
Old 18-02-2007, 06:23 PM   #9
ebfalcon13.5
grey bumperz
ive tryed searchin the forums for an ecu diagram but couldnt find anything somebody was told to goto http://www.mechanicalforums.com/ but this site doesnt work? anyone else know of a place to download it from? thanx
Old 18-02-2007, 06:48 PM   #10
MMD
http://fordmods.com/forums/documents.php?doc=41
MMD is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 07:11 PM   #11
AUTickford
XD197
AUTickford's Avatar
Simple and effictive, earth the negative wire of the coil to ground and have a switch and its meant to be heaps better than the switch to the positive because if you chase the wire into the harness a little and hide where youve tapped into the wire its really hard to find where as with the posive side can be bypassed with a wire from the battery to the coil. I read this in a ford magazine on an artical on car thefts, cant remember which one though. hope this helps
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 07:11 PM   #12
ebfalcon13.5
grey bumperz
cheers thats exactly what im lookin fo, but my eb is series 1 are the ECU's the same ?
Old 18-02-2007, 07:17 PM   #13
ebfalcon13.5
grey bumperz
sweet thanks thats an awesome idea so with the switch on, it would be shorting the coil straight out to ground! i should definately use a relay if im going to **** with the coil i suppose. wicked i should combine this also with the fuel pump switch
Old 20-02-2007, 12:08 PM   #14
Zedjay
Zedjay's Avatar
i had a kill switch hooked up to my lighter (previous car)
if the lighter was pushed in it goes,pull it out it stops
Zedjay is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 01:53 PM   #15
ebfalcon13.5
grey bumperz
awesomest idea ever, dont need a lighter in my car!
