06-03-2007, 04:27 AM | #1 | ||
hey guys
i have purchased some genuine BA fairlane side skirts and need to figure out how to attach them? from what ive been told they screw in with some tech? screws in the scuff plate area? where are these screws and or how do i get to them thanks guys
06-03-2007, 04:44 AM | #2 | ||
Forum Director
A tek screw is a self drilling screw. Much like a normal screw but with a drill bit machined into the end.
They can be obtained at just about any hardware store. I would be careful using them though, as the 'drill' part is not as finely made as a dinkum drill bit, any running off the intended target area could be nasty for paintwork. Personally, I would pre drill the holes with a good sharp steel bit. I think that skirts are generally also held on with an adhesive as well as screws, certainly the skirts on my ute are, as I could see the remains when I managed to tear one of them off. It looked a lot like sikaflex, but I could be wrong on that. |
06-03-2007, 07:12 AM | #3 | ||
Well they should have a few screws under the sill panel and a couple directly behind the wheels,then sikaflex if the door jamb area on the upper sill panel.
06-03-2007, 07:46 AM | #4 | ||
Also ... from what I remember seeing under mine (as I bought Mick's Factory kit for the ute) ... there are also flat clips that hold the skirt in place along the bottom sills under the vehicle.
06-03-2007, 07:55 AM | #5 | ||
There were no screws used in the scuff plate area when I did mine, if you (carefully) remove the rubber strip (that sits on top of the sill panel) the holes should mate up with the holes already in the skirt, from there it should just clip on. The underside is a different issue, you may need to use a few screws there but over all, mine was an easy conversion (considering there were none on the car previously).
Removed by laminge |
06-03-2007, 11:30 AM | #6 | |||
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
06-03-2007, 11:59 AM | #7 | |||
Adapt or perish...
Holes should line up pretty much 100%, I'm not sure if you need to get the skirts cut and plastic welded like the ute cabin skirt from BA to AU.
Carless
06-03-2007, 12:50 PM | #8 | ||
its a direct bolt on
was just wondering how they bolt/clip/glue on thanks for the info guys
06-03-2007, 05:03 PM | #9 | ||
Built Ford Tough
Fit them front first, not like the morons at Paja (who marketed the whole Peregrine Falcon thing and aren't in business anymore, at least not under the same name) who first fitted my Rebel side skirts rear first then tried telling me my car must be a bit short when there was a gap at the front they couldn't fill properly with Sikaflex...
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
06-03-2007, 05:57 PM | #10 | ||
hey blackers, what did you pay for them. the loons havnt got back to me yet.
07-03-2007, 01:55 AM | #11 | ||
$120 for the pair supposed to be $200 but Botch beng such a good fellow said i could still have them for $200 (he miss quoted me)
08-03-2007, 01:16 PM | #12 | ||
thats cheap!!!!! want a pic when you get them on. i dont mind the ba ones
