:D:D
Seem how everyone is into the 977b cam whick cam would you go for
1636 or 977b cams
Cheers Grant |
1636.. i have only had good results with this cam.. so has every one who uses it
jasinex
EA Series 2 now with fast parts added... Stage 1: Buy car. with money. Stage 2: Put in Wade Custom Cam, Crow Double Valve springs, High Flow Head, 3.23 LSD, 2.5" mandrell bent with Mercury muffler and custom made CAT, iridium plugs, nolothane bushes, Koni suspension, CAI.. NOW WITH MPFI....OHHH YEAHHH!! Stage 3: More engine mods.. and a fresh new look... can't wait.. :eclipsee_ ![]() 15.43 @ 89 mph - Willowbank Raceway 07/03/2007
Smash the Boost
wait till grechie runs his thing down the strip. I suspect 1636 FTW. Or hit up surecam for OED666's grind, throw that in with an AU motor and have fun (will need to spend $$$ on driveline to go as fast though)
Im sure Walki/BI6TIM will be here soon telling me how utterly soft I am cos its such a baby cam
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
XR6 Turbo FTW
Go for the 977B for sure if manual
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
@jas_23_
there is now a cam called 1636c977b, its a mix between the two.
manual 977b auto 1636.
my 1636 pulls hardcore up high in wet if im doing 40 in first, and plant it i wont loose traction at all, until i hit about 60-70 when the cam just starts hauling serious *** and the back loses it |
#7 | |||
XR6 Turbo FTW
ill let u know as soon as i can results on the 1636C977B, see my thread for more info...i will keep it updated
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
:D:D
i wouldnt mind to see what the 1636C977B runs down the 1/4 mile
Cheers Grant |
#10 | |||
XR6 Turbo FTW
:D:D
thats good just a touch faster than grechies car with the 1636. Grechie still might get 13s with his car
Cheers Grant |
#12 | ||
i dont think im 13 material yet, i however hope for 14.2
What's your previous PB? MPH?
Sundeep |
#14 | ||
14.43 @ 96mph with 1636 and 3.27 dif gears
now 3.45's and 1636C977B cam.
#15 | ||
V8 wannaabeee
can you actually feel much of a difference grechie.... compared to your previous cam?
#16 | ||
:D:D
u should get a bit quicker than 14.2 the 1636C977B should give u a bit more power then the 1636
Cheers Grant |
#17 | ||
@jas_23_
hows this new cam with the stock ecu
#18 | ||
Two > One
grechie is it the 977b on the exhaust lobe? What LSA was it ground on?
