Old 18-03-2007, 08:47 PM   #1
BLSTIC
Default tuning jag's
Just went out to tune up our XJ6 in the front shed, following the instructions in the workshop manual.
1st problem, wrong dizzy. That or wrong firewall tags, interior, and carbies. I know whats more likely though. Series 3 XJ6's never came out with points, and nothing that comes out with points has 'danger - electronic ignition' plastered to the coil.
2nd problem. Timing out so far I can't see the marks (the indicator for which is obscured by the factory air conditioner, go figure...). Guess-o-matic'ing the dizzy position gets it to 12* running.
3rd problem, Idle too high. To be expected after you get the ignition timing nearly right when it was last adjusted with timing completely wrong.
4th problem, Out of balance. Seriously, how hard is it to feel when the throttle shaft opens both carbies near enough to simultaneously. Guess-o-maticing got me closer again. Close to 6 turns of the throttle stop screws out (as in, adjusted one 6 turns, didnt touch the other) and it is still ages out.
5th problem, impatient people. Just guess-o-matic'ed to get everything near enough to follow instructions in the book (ignition timing was so far out the idle couldnt be set as per the book (and have the car running), and can't be set accurately until the carbies are near enough), and then the car is taken for a blockie by someone who can't be bothered waiting. Despite the fact that I told them that it will be wrong, they take it anyway. Backfiring up the street. After coming back they park the car in a different spot. apparently all they wanted was to move the car, so they could move the one behind it. As a consequence of taking it for a lap, as opposed to just moving it, they have pushed me over the limit of my patience, and taken my last 10 minutes of sunshine (it goes dark really quick here) required to tune the car outside. So now I have to start again tomorow.
[/rant]
cya
Ben
*P.S: you people are lucky we aren't allowed to swear on here. anyone who has had that string of events happen will know what I am on about.
Chuck Norris beat Tetris
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 08:54 PM   #2
gthofan
Gunna girlie-man
gthofan's Avatar
http://www.jaguarforums.com
this should help ya mate
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 08:57 PM   #3
BLSTIC
The problem really isnt the car, I can work around the dizzy. The only thing it would have come from is an earlier jag, so it wont be that bad. The problem is really my impatient stepfather and his bad timing...
Old 18-03-2007, 09:07 PM   #4
gthofan
Gunna girlie-man
gthofan's Avatar
hahha, if only you could get a timing light on him.
have you tried ringing jaguar australia? or a jaguar dealer?
ask for the service department, they should be able to tell you.
i know if i have a problem with my car, i just ring up my local ford dealer and ask the service guys. they tell me straight away.
Old 18-03-2007, 09:10 PM   #5
BLSTIC
Local Ford guys here don't tell you squat, they won't even let you look at their (supposedly $1200 each) workshop manual. I can see the timing marks, but its a ***** of a thing trying to both see the indicator and getting the timing light on it. It's do-able though.
Old 18-03-2007, 11:44 PM   #6
Rollin
Rollin's Avatar
1: Knock out stepfather
2: Ditch jag motor
3: Insert 4.0L I6 + matching gearbox
4: ....?
5: $$$Profit
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2007, 10:54 AM   #7
BLSTIC
Yeah, it would be cheaper too. Unless I bought a DOHC item and Haltech'ed it. Cams, exhaust, 6throttle induction system, and a 3000rpm stall on a C4, say hi to mid 13's...
but realistically, I reckon the only way is injecting the twin cam engine that's in there. I reckon with a decent induction system and a set of extractors it should be capable of laying down 150rwhp. Would drive and sound way better too...
cya
Ben
*oh yeah, I got it tuned as well as I can, it dies at high load, and the more rpm you get, the less throttle you can use. To me that implies that there is some kind of fuel flow limitation. Probably somewhere under the main jet needle.
