Old 05-05-2005, 03:59 PM   #1
richo77
richo77's Avatar
Talking Noisy XR8
Hello,
Whenever I give my car a bit of a rev such as when overtaking and the speed exceeds 120km/h or so, when i let go of the throttle there is a high pitched noise which sounds oddly like an alarm of sorts which continues sounding until you go back on the throttle or slow down to around 100km/h.
It is isnt the speed alert and i've turned off the stereo so I have no idea what it is.. but it seems to be coming from the centre console/dash area.
I was reading an old issue of Motor from 99 when they took an AU 1 XR8 around Oz and they said a similar thing happened with revs at 3500rpm - 160 km/h but couldnt describe the cause.
Any ideas? Ford doesnt know!
cheers
Nathan
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 06:16 PM   #2
Pete A
Boss 260
I gather your car is AU1. I had AUII for 4 years and my son has AU111. Never heard of this problem. Might be fooling you on where the sound is coming from. If you have the Windsor 5.0L V8 then I would suspect something stupid like the force air inlet manifold has a problem at certain stress levels.
Could also be something stupid like the fan belt vibrating or a bearing in the engine somewhere.
I know the V8's pretty well but if you have a 6 - sorry can't help.
Pete A is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 06:37 PM   #3
richo77
richo77's Avatar
Hey there thanks for the reply
Its an AU XR8 Series 3 - sillouette with polished rims and no mods other than a K&N panel filter (which makes no noticeable diff to power or fuel economy). :eclipsee_
I'm pretty certain the noise is coming from the dash and is so annoying and instrusive! Motor called it a 'wicked internal buzz'. I'm thinking of pulling out the dash to see if it happens without it in. If thats not it then i've got nfi!!
Regards
Nathan
Old 16-05-2005, 07:01 PM   #4
cArSiK
your not the first person to complain about this....so i suspect alot of them do it? I know my AU2 XR6 dosent do it...
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2005, 08:53 PM   #5
RspecAU
BA GT-P Owner
RspecAU's Avatar
The only thing i could think of is it maybe a leak in the vaccum system to the heater controls...if the noise is coming from the dash but i'm only guessing
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
