Old 10-04-2007, 07:08 PM   #1
FS5
Default series 1 xr6 auto engine into series 2 5 spd
hi guys , i'm going to be doin an egine swap soon.i am going to be putting an au series 1 xr6 auto engine int our au 2 5 spd.
i had a look at the engine today and noticed that the looms and wireing are a bit different.the black looking loom that sits above the bbm near the fire wall is the same.but there is another wireing loom that comes out below this with a couple of plugs attached .one roud one and a smaller squre one.considering this engine is out of an auto ,do these have something to do with the auto?
i also noticed the tps is different to whats on mine.
i'm guessing it will probably be easier if i swap the wireing loom,sensors and throttle body of my series 2 .
i know the injector's will be fine.but are the crank angle sensor and cam sensors the same in au 1 and au 2?
thanks for your help
jake
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 07:21 PM   #2
EvilChief
Boost Addict
the engine wiring as such will be the same, there is a diff between auto and manual wiring looms, oterh than that all sensor are the same, will be a direct swap
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 10-04-2007, 08:31 PM   #3
bodes-sh
au 1 and au 2 also have different coil pack plugs, that's why they list 2 different coil packs for them, au 2 is more of a square plug, whereas au 1 is more oval shaped
Old 11-04-2007, 01:19 PM   #4
FS5
thanks for the info guys.
Old 11-04-2007, 04:28 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
Just a tip incase you hadn"t thought of it. don"t forget to change the spigot bush (fly wheel bearing) located in the end of the crank to take a manaul box input shaft ... :
Originally Posted by Riksta
