Old 04-05-2007, 10:56 PM   #1
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Default AU indicator probs
Hi all. I was driving the wifes AU tonight and i parked illegally and put the hazards on and all the indicators just stayed on ie no flashing. Now when turning either left or right its the same story. Im thinking relay or flasher. Any ideas ? Thanks in advance.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 12:18 AM   #2
mattp
mattp's Avatar
Something similar happened in my old EA, just the hazard switch on top of the steering column had gotten stuck. Give it a fiddle, it may or may not help; if it does it's a cheap fix, if it doesn't, nothing lost.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 01:45 AM   #3
chief
FTF Club Moderator
chief's Avatar
Hot after the fix on my wipers. This same problem has happened to me. Sounds like I have electrical gremlins in the car. I look forward to this thread.
Albert Einstein:
Fords in the Park 2010
Old 05-05-2007, 07:29 AM   #4
au2sw
Blown 5L coming
au2sw's Avatar
it will be the flasher relay, you'll find it in the relay box under the bonnet. change it and the indicators/hazards will flash again.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 07:33 AM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
the flasher can is actually in the fuse box on the underside of the dash near your right knee
Old 05-05-2007, 09:44 AM   #6
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Spot on mate. Gave the hazard switch a bit of a wiggle and its all back to normal now. Thanks guys.
Old 05-05-2007, 02:08 PM   #7
FGII-XR6
FGII-XR6's Avatar
If I were you I'd replace the Hazzard switch now if it has done that once it will fail completly at the most inconvenient moment don't give it the satisfaction
Old 05-05-2007, 03:19 PM   #8
chief
FTF Club Moderator
chief's Avatar
Fixed my indicators. Taking not of how to fix your power windows, I simply tool out the relay cleaned the contacts and put it back in. 30 seconds work and the indicators are functional again.
Albert Einstein:
Old 05-05-2007, 03:36 PM   #9
Noddy
Mercury Silver T3
Noddy's Avatar
I have something similar happening on my T3. When i disarm the alarm it flashes twice as it should do but then i find buy the time i'm sitting in the drivers seat the hazzards flash two to three times. Anyone know what that is?
House of Tickford
T3 TS50 No.156
AUIII XR8 220
2017 Magnetic Mustang
What to hear a tuff T3?
Click here
http://s7.photobucket.com/albums/y30...ent=Movie2.mp4
Noddy is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 06:39 PM   #10
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Unreal isnt it. Im liking these quick fixes. LOL
Old 05-05-2007, 06:42 PM   #11
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Yeah will do mate as i have tried the hazards throughout the day whilst driving (no other cars around) and it pretty much plays up everytime, so if the missus is driving it and has to use hazards i dont it playing up for her. Thanks for the advice, i will replace it straight away. Cheers Mate.
Old 05-05-2007, 06:43 PM   #12
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Maybe issue with the alarm itself. Sorry not too sure. Hope you find a solution.
Old 05-05-2007, 09:19 PM   #13
Umineko
Karasu
Umineko's Avatar
It means the Alarm is reporting an incident of some type... could be anything from a low back-up battery to an alarm trip from door, bonnet etc. The number of flashes will tell you what the condition is, turn the alarm off then on with the alarm key and it should reset and clear the fault.
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 09:20 PM   #14
Umineko
Karasu
Umineko's Avatar
Oh and a list of reporting codes is in the owners manual
Old 06-05-2007, 09:17 AM   #15
bodes-sh
you could also try blowing compressed air/wd40 or something into the top of the switch to clean a bit of the dust out that gets in there
