Spin 'em Habib !
Need a Hand Installing a head Unit into my car , anyone that can help will be looked after ..
Cheers Daniel
AU2PWR |
The Mod Bug Has Hit
Hey mate what part do you think you would have trouble with:
Removing the old one? Making the Wiring Loom? Running speaker Wires? Installing the new one including making mounts? All if the above? Thanks Jake
www.aufalcon.com/jakesfalcon
#3 | |||
You can't stop the signal
when you looking at doing it daniel. I've been there done it before, just hope it doesn't take as long as it did for me (about a week)
i live in Oakleigh and done a heap of stereos for mates and the One in my AU XR8
One Really good suggestion is to go to J.B Hifi and ask for an adaptor for the AU they might have the right one for your head unit so no cutting of wires just plug and play. If they don't have one to suet your head unit buy one and cut it to make your own adaptor harness so you don't have to cut the factor wiring which is what i had to do for my Head unit
MR INCH
And make sure u get the right au single din pocket, fits much better than universal ones and helps mount the stereo. And yeah do what toyotaxr8 said. Just finished puttimg a system in my bro's au, i will try and get some of the pictures we took.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto ![]() Soon to be painted running a 4.0ltr v6 ![]() See the build here http://www.fordforums.com.au/showthread.php?t=11388068 You Have Freedom of Speech Just Choose to Remain Silent |
X-Series Club Moderator
I have a set of head unit keys for an EF.... which I'm told are the same as an AU. If you wanted to swing by my place I'm sure we could get it out! PM me if you like.
Otherwise there's the 'persuasion' method I had to use on a mates AU head unit that had been removed, the tags broken off the pins and then re-installed at a later date. Had to detach the face off the fron of the unit... not pretty when you consider AU unit's are non-detachable! |
#7 | |||
GT-P #0336
http://cgi.ebay.com.au/FORD-FALCON-A...QQcmdZViewItem
![]() ![]() ![]() ![]() ~Tuned By Bluepower Racing~ |
OLD SKOOL BABY
Pm Sent
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.![]() 1976 XB GS COUPE (waiting to start the rebuild)
not here much anymore
Aerpro make those adaptor looms to suit AUs, you just grab the one based on what head unit youre using, they do them for Alpine, Pioneer, Clario and Sony from memory. If you cant find one let me know, I have them all in stock at work.
2024 F150 XLT
