13-05-2005, 02:36 PM | #1 | ||
just wandering im converting my auto to a t5 manaul out of an ea when i finish painting my car. just wandering will everything off the ea fit my eb and will i need anything else. hopefully will start the conversion in the next few weeks.
cheers scott |
13-05-2005, 02:41 PM | #2 | ||
there's heaps of threads about it, just do a search.
i got quoted $1650 from city dismantlers in Adelaide. thats a self-install kit with trade-in on auto box.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
13-05-2005, 03:01 PM | #3 | ||
hibernating
When i converted my car to manual I looked around a bit and managed to get everything I needed from a wreckers out of an EB series 1 for $500.
13-05-2005, 03:03 PM | #4 | ||
yeh ive bought the ea with the 5 speed so i just need to know will everything from it fit my eb and if not what will i need.
thanx scott |
13-05-2005, 03:04 PM | #5 | ||
hibernating
it will all fit, does your eb have smartlock or not? if it has smartlock you might need to get an ecu that has smartlock.
13-05-2005, 03:14 PM | #6 | |||
-Dave- |
13-05-2005, 03:17 PM | #7 | ||
yeh mine has smart lock so will i need to change anything
13-05-2005, 03:19 PM | #8 | ||
hibernating
i'm not sure if the ea ecu will work since its pre smartlock. but you can still use the auto ecu thats in your eb now and it should work fine. i have put an auto ecu in my car just to see how it would run and it seemed exactly the same, only thing is the idle went up about 500rpm, which you can easily adjust.
13-05-2005, 03:24 PM | #9 | ||
do you have to trick the ecu or something?
13-05-2005, 04:14 PM | #10 | ||
Two > One
Presmartlock will work in smartlock cars. Just not vice versa.
You could run your EL XR6 on an EA CFI ECU if you really really wanted to.
13-05-2005, 04:40 PM | #11 | ||
NOS Induction pssssshhhhh
you can still use the auto computer, without tricking it i had the auto one in my car for about 1 year b4 i found a ed xr6 manual computer for it. all you need is the manual pedal box, clutch cable, manual flywheel, wiring harness and the middle section in the centre consol everything else yuou can use from the auto. tail sharft, transmition mount there the same as the auto ones in the ebs not sure about the ea's.
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall . --------------------------------------------------- I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh |
13-05-2005, 04:55 PM | #12 | ||
this is actually pretty interesting guys, keep it all coming - i might be able to source some of these parts for my conversion from a mate who works @ mt barker wreckers
i cant imagine the clutch cable/flywheel being any problem... dont know about the pedal box. Is the wiring harness difficult to source?
13-05-2005, 05:06 PM | #13 | ||
so walkinshaw if i put the manual ecu out of the ea in to my eb with smartlock it should ok is this correct?.
13-05-2005, 06:21 PM | #14 | ||
Smartlock won't work 100% though. You should still have remote central though.
13-05-2005, 06:32 PM | #15 | ||
Two > One
It should be allright mate. When i had some wiring problems we used an EA MPFI computer and my ELengined/dash/interior'd EA fired up no problem.
